I have a squeek that sound like it's coming from the front springs on the driver's side. Someone posted up with the same thing and mentioned using spring isolators. They were described as a plastic wedge that goes between the leafs on the spring. Where do you buy these? I called the dealer because I thought it might be a dealer only item and they said I would have to buy the whole spring assembly. I called a couple local places with no luck. Anyone have any ideas or suggestions? THANKS!
Dave, found this in the "search" part of forum.
#4 10-15-2007, 03:58 PM
WILDMAN_Stroker*7.3
"SWOSU" BULLDOGS Join Date: Aug 2006
'I got a kit from powerstrokershop.com at $22.77 for the kit. Part #1C3Z5B302AA "
Ford dealers do carry them or can get them. If not try the above. Hope this helps, Carroll
