Spring Isolator
Old Jan 12, 2008 | 12:09 AM
00Dave's Avatar
00Dave
Spring Isolator
I have a squeek that sound like it's coming from the front springs on the driver's side. Someone posted up with the same thing and mentioned using spring isolators. They were described as a plastic wedge that goes between the leafs on the spring. Where do you buy these? I called the dealer because I thought it might be a dealer only item and they said I would have to buy the whole spring assembly. I called a couple local places with no luck. Anyone have any ideas or suggestions? THANKS!
Old Jan 12, 2008 | 05:34 AM
Calli's Avatar
Calli
Dave, found this in the "search" part of forum.
#4 10-15-2007, 03:58 PM
WILDMAN_Stroker*7.3
"SWOSU" BULLDOGS Join Date: Aug 2006
'I got a kit from powerstrokershop.com at $22.77 for the kit. Part #1C3Z5B302AA "
Ford dealers do carry them or can get them. If not try the above. Hope this helps, Carroll
Old Jan 12, 2008 | 09:47 AM
PaysonPSD's Avatar
PaysonPSD
Here is a link to TSB 99-16-3 about front spring squeak and isolators to fix it:
https://www.ford-trucks.com/tsb/full...hp?tsb=99-16-3
Old Jan 12, 2008 | 07:47 PM
00Dave's Avatar
00Dave
Thank you for the info!! I will look into getting the parts. Rep points left!
rugermack
Dec 25, 2014 11:20 PM
bigb56
Sep 8, 2014 09:04 AM
Methodical_1
Aug 30, 2012 07:43 PM
shane7209
Apr 28, 2011 11:04 AM
DL
Apr 19, 2007 08:39 AM
