Caliper problem or slide pin problem?
Old Jan 11, 2008 | 07:19 PM
IDPisan's Avatar
IDPisan
My drivers side caliper is not releasing after I let off the brake. When I apply the brake it does not pull to one side or the other. Am I looking at a new caliper or doing Guzzle's slide pin replacement?
Is the early 99 part number different than the 2C3Z-2C150-AA?
Thanks in advance !!
Old Jan 11, 2008 | 07:27 PM
Ed in Maine's Avatar
Ed in Maine
I would just pull the pins and lube them up good. Only if they are bone dry and rusty would I get new sliders. The last time I had brakes hold up on the rotor it was the right rear and I bought a rebuilt caliper for something like $60 after core swap, the sliders were freshly lubed up before the calipers locked up. I think the piston was not sliding smoothly in my case, due to a bad boot seal. Don't bother purchasing a caliper rebuild kit, they are almost as much as rebuilt caliper!
Old Jan 12, 2008 | 12:44 AM
IDPisan's Avatar
IDPisan
Anyone else have a thought about this ?
Old Jan 12, 2008 | 09:59 AM
IDPisan's Avatar
IDPisan
Heading out to get parts any more suggestions ?
Old Jan 12, 2008 | 10:06 AM
1996pwrstrk's Avatar
1996pwrstrk
Did you pull it apart yet?
Old Jan 12, 2008 | 10:09 AM
IDPisan's Avatar
IDPisan
Nope, I have to use my truck to get parts
Old Jan 12, 2008 | 12:54 PM
1996pwrstrk
I had to go out for a while did your tear into it yet?
Old Jan 12, 2008 | 06:08 PM
lee231's Avatar
lee231
I've ran into two that hung up on me, one on the car and one on the trk. The problem turned out to be the flex hose for the brake. what happens is the hose gets a blister on the inside, it lets the fluid in, but wouldn't let the brake fluid go back to the master cylinder and makes the caliper hang up.
Old Jan 12, 2008 | 07:53 PM
IDPisan's Avatar
IDPisan
Slide pins moved freely, replaced caliper and everything works great now .
Thanks for your imput !!
maxtruck00
Jul 26, 2014 07:16 PM
garydmundy
Jun 22, 2013 06:13 PM
PSNut
Oct 18, 2009 04:31 PM
Jim59
Oct 26, 2006 04:55 PM
bigrunnner
Jul 13, 2006 02:21 PM
