router / hub question...
Old Jan 11, 2008 | 10:50 PM
rhw's Avatar
rhw
Can someone tell me if it's possible to have a hub fed from a wired router in another room? The wireles Lynksis router is on the other side of the house and I have a cat-5 cable hard wired out the back, running to my room. Can I take the cat-5 from my computer and feed the in port of a hub that branches out to other rooms? (I tried a Trendnet wireless card that I gave up on-see previous ranting thread! lol) Also would it slow down my connection any? Thanks for any advice!
Old Jan 11, 2008 | 11:49 PM
donjamer's Avatar
donjamer
Yes you can..
That is usually what a hub is used for.. You have 1 active line and feed to a HUB or switch to add more lines..
The only draw back is yo do not want to run to many PC's off of the 1 line and it is not good to add another hub off this Hub...
Note: It is not recommended for performance reasons, nothing bad will happen if you exceed the amount of equipment..
How many PC's you intend to run?
Old Jan 12, 2008 | 01:21 AM
rhw's Avatar
rhw
Thanks for the input, I plan to run just one more off the hub. So, I have a wireless/ 4 port Lynksis router running two computers, an xbox, and then my line which will go into the hub and out to my computer and one other.
Old Jan 12, 2008 | 04:53 AM
tewferford's Avatar
tewferford
Is any of that equipment you mentioned wireless? If not, you might want to pick up another switch with more ports.
Old Jan 13, 2008 | 12:32 PM
rebocardo's Avatar
rebocardo
Most hubs have a port (last one #4?) or a switch (swaps in the last one), that lets you piggyback another hub there without having a cross over wire.
ddrumman2004
Jul 17, 2009 10:43 AM
packrat56
29
Nov 25, 2007 07:20 PM
cjben
20
Nov 13, 2007 09:25 PM
WhëëlMå1
Nov 29, 2003 03:34 AM
MustangGT221
19
Jul 27, 2003 12:16 AM
