Problem with the factory Holley
Old Aug 20, 2002 | 11:27 AM
strterl's Avatar
strterl
Recently, I had to remove the float bowls on my 460's factory holly 4 barrel to clean some junk that had gotten into them. There is a tube feeding the fuel from the front bowl to the back bowl that has 'O' rings on either end that comes out when you pull the bowls off. I got new 'O' rings when I reinstalled the bowls and the connecting tube. Problem is that I now have a leak between the front bowl and the tube. I've had the bowls apart and back together several times and can't stop the leak.
Has anybody had this experience and if you did, what fixed it"
Thans for the help.
Old Aug 20, 2002 | 12:08 PM
beetle's Avatar
beetle
Here's what I do: Install both o-rings on the very edge of the tube, do not roll them up to the "raised stop", put a tiny amount of grease on them. I've done it this way many times, never had a leak.
Old Aug 20, 2002 | 05:19 PM
strterl's Avatar
strterl
Thanks for the tip. I'll try it this weekend. I was rolling the 'O' ring down to the shoulder.
Old Aug 20, 2002 | 07:33 PM
pickupman79's Avatar
pickupman79
cedman
16
Oct 29, 2015 01:48 AM
Tdoyle03
Apr 1, 2015 02:05 PM
5280
May 4, 2014 09:30 PM
SSSimon
23
Jun 7, 2012 03:18 AM
08gasurveyor
41
Jan 20, 2012 09:05 AM
