13 " flywheel
Old Feb 28, 2001 | 07:03 PM
elliott's Avatar
elliott
13 " flywheel
If the blocks on 370,429,& 460's are the same, then the bellhousings should interchange. If I want to put a HD 5sp truck trans behind a 460, I need to find the proper bellhousing. Now, will a 13" flywheel off of a 370 or 429, fit on a 460? Thanks, Elliott
Old Feb 28, 2001 | 07:17 PM
greenhighboy's Avatar
greenhighboy
13 " flywheel
I bought a blown up 460 several years ago that had this setup on it.It was used to run an irrigation pump.It was externally balanced.I still have the bellhousing but not the flywheel.I think a 370 flywheel is the same.
Dennis Palmer
Old Aug 20, 2002 | 07:33 PM
pickupman79's Avatar
pickupman79
13 " flywheel
it will work ... 370-390
Old Aug 20, 2002 | 08:19 PM
phantom429's Avatar
phantom429
13 " flywheel
