blocking off fuel bowl drain?
I put a NAPA fuel filter/water separator on my truck when I did the Hutch/Harpoon mod so there's no worries with water reaching the fuel bowl itself. The fuel bowl drain valve is leaking again. I have a healthy supply of the proper "O" rings but it's a pain in the rear/back/knees to replace them with my age/lack of eyesight/lack of agility, etc to get the job done. Can the drain tube just be blocked off with the mod that has been done or is the fuel bowl delete mod the way to go?
Your fuel bowl needs a rebuild kit installed. That... or live with the leak.
I'll edit my post here to remove the question and any reference to it, and will and leave my comment as the following...
Evidently, JB Weld can be quite useful when required. Personally, I'm not sure how it will hold up to the diesel environment over time, but it does seem to be an option.
Understood. Thanks. It might just be fine, then. At the same time, though, and I may be wrong, but I suspect that outboard power head doesn't get near the run time as one of our trucks over the same three year period.
get the Fluorosilicone MilSpec M25988/2 not the viton type o'ring and the issue goes away for a LONG time.
Ford 7.3 Diesel Fluorosilcone Drain Valve O-rings
do the rest of the o'rings and hose fittings while in there and forget about this for a while.
cedman... The fluorosilicone will certainly do the job... they have worked exceptionally well on each of the fuel bowls on three different 7.3 engines for me over the years.
Once you do the next tear down, make sure to use a small pick, tiny flat blade screwdriver, and/or some very fine steel wool to carefully clean out all residual from the existing o-rings before installing the new ones. Clean mating surfaces which are free of any contamination really helps the new o-rings establish the most solid seal possible.
