Anyone have chewed up ring gear problems????
Old Aug 18, 2002 | 10:43 PM
phantom429's Avatar
phantom429
I have heard from a few locals that when using a 390 flywheel in a 460 application, the starter tends to not mesh properly with the ring gear and cause early failure. Is this just a folklore or is there some truth behind this ???
Nick from the frozen north
1974 F-250 4X4
soon to be 429
dana 60 front and rear
Old Aug 18, 2002 | 11:16 PM
LxMan1's Avatar
LxMan1
You can't use a 390 flywheel on a 460. They are two totally different engine designs!!!
Old Aug 19, 2002 | 04:20 PM
phantom429's Avatar
phantom429
The ford 390 flywheel has beed used by many people on this forum in a 460 application. They both share the same crankshaft bolt pattern. As far as I know they are even the same part number as the 460 flywheels.
1974 F-250 4X4
soon to be 429
Old Aug 19, 2002 | 10:04 PM
gray79f250's Avatar
gray79f250
No problems with the ring gear. Txman you are very incorrect. Since I have done my swap I have seen a page out of a Hollander interchange book and the 460/390/360 all take the same replacment flywheel.
Andy
Old Aug 19, 2002 | 11:03 PM
LxMan1's Avatar
LxMan1
I stand corrected, I thought that they were balanced different. Sorry.
Old Aug 20, 2002 | 02:41 AM
phantom429's Avatar
phantom429
I think we have all learned something today. All hail the all knowing forum of Fordness.
1974 F-250 4X4
soon to be 429
Old Aug 20, 2002 | 11:59 PM
trinogt's Avatar
trinogt
I recently replaced my 460 flywheel/ring gear on my 76 460 with C6 auto. It was so chewed up it only had about 20 degrees worth of teeth left to start the truck with!
I also replaced the starter drive gear set, which cost me only 7 bucks extra. (it got chewed too!)
Check out trans pump seal and rear engine oil seal while you're in there... Good time to fix any leaks!
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
Old Aug 21, 2002 | 12:42 AM
phantom429's Avatar
phantom429
I was reffering to a manual transmission with the flywheel. But that is a good pointer for those with autos.
1974 F-250 4X4
soon to be 429
Old Aug 21, 2002 | 08:38 PM
trinogt's Avatar
trinogt
Oh, sorry! Yeah, never worked on a manual trans before. Every single vehicle I have had with manual, be it rear wheel drive sports car (300ZX turbo) or 95 F150 5 speed, I have never had to replace so much as a clutch before. So, I have nothing to offer there, except the rear seal inspection!
Mark
Old Aug 22, 2002 | 07:58 AM
Just Strokin's Avatar
Just Strokin
If you have a manual tranny, the start ring gear on the flywheel is replaceable without have to replace the complete flywheel.
Another old trick is to 'knock' the ring gear off the flywheel and flip it over and use the other side. To do this, you will need access to an oxy/act torch so you can heat/expand the ring gear some to press/slide it back on.
When you go to put the ring gear back on, rotate it some so the worne teeth aren't in the smae place they were when you took it off.
FYI....the starter engages the flywheel, manual or automatic, only in three places.
Old Aug 22, 2002 | 06:51 PM
trinogt's Avatar
trinogt
Huh? Three places? Doesn't is hit the first tooth that comes along after shutdown? My old ring gear shows wear everywhere, but worse in a couple spots oppostite eachother...
Mark
Old Aug 22, 2002 | 08:57 PM
mike460's Avatar
mike460
Brian429
2015 - 2020 F150
Nov 23, 2016 11:51 AM
choppermanjapan
Dec 24, 2015 01:01 PM
badblueoval4life
2009 - 2014 F150
36
Jan 22, 2008 09:10 PM
yomow
Apr 17, 2004 09:00 PM
74crwcb429hibPS4spd
Mar 20, 2003 06:46 PM
