429 Boss
429 Boss
Question ??? , will a set of alm. cyl head's fit a 429 or 460 engine & if they do, would the work good or Great ! The local shop down the shop sell's EM . But I'm asking you guy's not him. He build's Boss 429 Race engines. And bought the molds from Ford years back . He can only build alm. blocks & heads
I have a 460-4v prem fuel ,from a 72 lincon w/ c-6 I could put in my next 65cc sb
Don
Don
on
To use a Boss head on a standard 429 will require you to do more than just run the heads...for a start the Boss 429 had different rods and pistons. The pistons have a unique dome to fit the profile of the Boss head. You'll also need to buy the Boss valve covers, intake manifold, have headers custom built, etc.
Unless money is no issue with you it would be much cheaper to purchase a set of aftermarket heads like the Edlebrocks.
Deen
Deen
As Deen said, unless you have some pretty deep pockets, you would be better off with the TF, Edelbrock or Ford CJ aluminum heads. Personally, I like the Trick Flows the best. Better flow numbers than the Edelbrocks (almost even with the Ford aluminum CJ head) and still use the smaller intake port for more bottom end "oomph" only down side is TF is running about a 2 week backorder from time of order to delivery on the new heads (mine are due in next weds)
Ok, as for now .
{Is} the block's farly much the same on 429 , 460 & Boss 429??
Heck I want a boss engine for my 65 . I've had boss 351's, I can't aford $84,000 For his alm . Boss 429 engine But I'm willing to leave this World running ONE!!!If I can !!!! In cast Iron. Ball_ to the wall. If you know what I mean.
Don !!!!!
Don !!!!!
