Aerostar Ford Aerostar
Installing tach - 1995 3.0L?
Old Jan 10, 2008 | 08:08 PM
Bax2008's Avatar
Bax2008
Question Installing tach - 1995 3.0L?
I did a search and saw many conflicting posts.
Is this accurate? Thnx.
I personally recommend installing a tachometer, which is really east to do on an Aerostar. The easiest way to power the tach is to get on of those fuse taps. You simply plug the fuse tap into a fuse that only gets power when the ignition is turned on. You can tie the tachometer illumination to a circuit that powers the dash or running lights. The tachometer signal requires that you feed a wire through the firewall. This wire will connect to the tach terminal, a tan colored wire pigtail located in the area above the power steering. Just put a spade connector on the tachometers signal wire and plug it into this pigtail.
Old Jan 10, 2008 | 10:39 PM
DCRB's Avatar
DCRB
yeah pretty much, accept when i installed my tach i used t taps to access the ignition power from the radio wires, and for the light on the tach i tapped into the power wire for the light in the ash tray, (so that i can dim the tach as well) then i looked in my haynes manual to see which wire is the negative wire on the coild pack then used a t tap for that too, then grounded the tach and the light to the chassis.
in case you're wondering what t taps are, they are the plastic things that attach to existing wires at a 90* angle (making them look like a T) and use standard flat male plugs to plug into them
Old Jan 11, 2008 | 12:24 AM
asavage's Avatar
asavage
FTE Community Team
The 4.0l apparently has a tach terminal available. I spent considerable time looking for an equivalent on my '93 3.0l and never found anything suitable. I ran a wire through the firewall -- I drilled through the clutch master cylinder block-off plate (mine is AT) for the grommet. I needed a tach signal for my remote start setup (I can now start my Aero from inside the house, to thaw the ice on the windscreen). Months later, I tapped into my new tach signal wire under the dash for the tachometer.
The location I chose was this one, slightly to the passenger side of the center of the engine bay (click on any image for larger):
Note that Ford changed the engine bay wiring harnesses over the years. In particular, the older, round-connector harness probably does not have the tach signal, because the TFI module was on the distributor back in those days.
And the 4.0l has a tach terminal wire just hanging loose from the harness, but still on the engine side of the firewall.
The Electronic Instrument Cluster (digital dash) on the later ('92-on) Aeros apparently has a tach signal too -- but also has a tach!
Old Jan 11, 2008 | 05:59 AM
96_4wdr's Avatar
96_4wdr
T taps are too easy to use but cause damage to wiring and a nightmare of intermittents from wire cutting and corrosion. they are not sealed, just a mechanical connection cutting into the other wire.
i would never use one on something critical like brake or tail lights.
cut the wire and solder the three together for something permanent like a tach. use heat shrink to seal from moisture and insulate.
first check your tach and make sure it is compatible with the type of Ford ign. you have older 3L dist. is different than later 3L and the 4L with EDIS
most tach manufacturers have a site with compatibility lookup
check the fuse block above the left kick panel under the dash for a ign key switched connection. there are a couple that take a push in spade
nice pics, asavage, new camera for Christmas?
good flash work
Old Jan 11, 2008 | 09:01 AM
asavage's Avatar
asavage
FTE Community Team
I've gone through a pile of digital cameras since the first one in 1997 (Ricoh RDS-5000, $750). Current one is over a year old, from Costco, Olympus SP-350, $200. It is far from perfect, and I am looking for its replacement already, but it's pretty good for a $200 camera. Macro mode won't focus (defective), and Super Macro won't flash (WAD). Color balance is unusually good for a camera in this class though. I am a lousy photographer, but if you take enough of them, you're bound to get better. I take pics of everything these days; you never know when you'll want a pic of something later. Problem is organization.
I use tee-taps for anything inside the car, but if it's outside it gets soldered. Solderless connectors and tee-taps are nothing but trouble if exposed to weather here in the Great Pacific NorthWet.
Old Jan 11, 2008 | 09:28 AM
kaboom10's Avatar
kaboom10
If you don't mind me asking what tach are you using? just curious.
Kaboom10 2002 5.4L 4wd F-150 w/33k/miles<O</O
K&N replacement filter w/modified air box<O</O
EBC brakes all around
<O>http://i48.photobucket.com/albums/f240/kaboom10/100_0165.jpg</O>
Old Jan 11, 2008 | 01:55 PM
Bax2008's Avatar
Bax2008
Kaboom10 2002 5.4L 4wd F-150 w/33k/miles<o></o>
K&N replacement filter w/modified air box<o></o>
<o>>http://i48.photobucket.com/albums/f240/kaboom10/100_0165.jpg</o>>
I am considering
http://sunpro.com/product_detail.php?pid=16474
Old Jan 11, 2008 | 08:23 PM
Bax2008's Avatar
Bax2008
Got my tach installed today.
I managed to trace the tach wire from the RemoteStart.
Thanks for all the responses.
JoeNoble
Aug 15, 2015 09:18 PM
Zebich
Feb 20, 2005 10:20 PM
Nightrain
Dec 24, 2004 10:01 AM
jeandras
Electrical Systems/Wiring
Jan 29, 2002 12:00 PM
terragate
Modular V8 (4.6L, 5.4L)
Jan 4, 2002 04:41 PM
