Show Off Your Pre-97 Trucks
Old 03-25-2010, 03:36 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
Originally Posted by pantans
Actually, very anemic...
I'd imagine so.
Beautiful trucks guys
  #3692
Old 03-25-2010, 04:39 PM
J1nx93's Avatar
J1nx93
J1nx93 is offline
Originally Posted by 6CylBill
Chris, you putz, you have a locker. It just means your truck is hooking up like it should.
I've been trying to get a good picture of betsy lately. For some reason I can't capture a good shot. I think I need to take the truck somewhere where there's a prettier background.
Might help if I wash her, too. lol
This summer you need to head down to Monroe County to get some shots with me. There's a creek and a lot of fields.
  #3693
Old 03-25-2010, 05:06 PM
nflfreak43's Avatar
nflfreak43
nflfreak43 is offline
Originally Posted by skyfox10
Even with the locker, I would think that truck should spin the tires easily with that ratio. my last 351 3.55 setup could burn both tires all day long.
yeah well i cant figure it out. it feels like it has no low end power. when i floor it it feels like nothing. now when im cruising and then floor it i really feel the power. its almost like the timing is off some. im gonna readjust the timing hopefully this weekend to 12* and see how it runs then.
  #3694
Old 03-25-2010, 05:37 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
Poser pics!!!! I'm such a loser, I know.
Look how cool I am with my body lifted two wheel drive truggy.
Ooohh look, I can climb an ant hill.
  #3695
Old 03-25-2010, 06:31 PM
93 mix 'n match's Avatar
93 mix 'n match
93 mix 'n match is offline
made it that far and the right rear started to spin....didnt lock it bill?
  #3696
Old 03-25-2010, 07:02 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
It stays locked, Mr. Louis. One tire always drags like that when I'm taking a tight turn.. It doesn't mean I'm losing traction, it just means both tires are turning at the same time, so one side or the other is going to chew up the dirt / gravel / cats / babies.
  #3697
Old 03-25-2010, 07:21 PM
EricW.'s Avatar
EricW.
EricW. is offline
I'd say that too if it were me....
  #3698
Old 03-25-2010, 08:21 PM
93 mix 'n match
ahh makes sense now that i think of it. if i didnt know you had a locker the gravel would make it look like the pass. tire started spinning.
  #3699
Old 03-25-2010, 08:29 PM
SaikotikGunman's Avatar
SaikotikGunman
SaikotikGunman is offline
You can tell it has trac, it was the inside wheel that was slipping!
If you're losing traction, and both wheels have power, it'll generally be the outside that spins first, since it has further to go.
Of course, these pictures show why I'm sort of hesitant about getting a locker. I'm leaning more toward a mechanical limited slip that doesn't use clutches.
  #3700
Old 03-25-2010, 09:47 PM
93 mix 'n match
not if the inside wheel is almost off the ground...
if you have an non locked diff and your going sideways up a hill like he is, the inside wheel will spin.
  #3701
Old 03-25-2010, 10:01 PM
300 Buster's Avatar
300 Buster
300 Buster is offline
Us 2 wheelers can do them small hills! We just attack them faster!!
  #3702
Old 03-25-2010, 10:02 PM
Casey429's Avatar
Casey429
Casey429 is offline
Originally Posted by sharp94xlt
My first truck: 94 302/E4OD 4x4 40/20/40 seating. Sold it a couple years ago and still miss it.
Yes! Another Calypso/Tourmaline '94. Did yours have a manual T-case or electric? Mine has the same specs as yours, and now I know it will look great with a toolbox.
  #3703
Old 03-25-2010, 10:11 PM
SaikotikGunman
I'm still not sure about that... I thought an open diff would favor the outer wheel?
  #3704
Old 03-25-2010, 10:25 PM
93 mix 'n match
which ever wheel can spin easier. in bills case, most of the weight is on the outer wheel and the inner is barely touching the ground.
as we all know, weight=traction. so the inside wheel would start to spin if it were open. i know this for a fact because i would park like bill has done all the time in my old 93.
  #3705
Old 03-25-2010, 10:50 PM
EricW.'s Avatar
EricW.
EricW. is offline
An open diff will favor which ever wheel is off the ground...
Quick Reply: Show Off Your Pre-97 Trucks
