460 x pipe
Old Aug 13, 2002 | 08:20 PM
merc460's Avatar
merc460
460 x pipe
I had this posted in the exhaust section and although I received a excellent reponse from Willian in Atlanta. I was hopping for more debate and Info.So I will post it here to see if my fellow BB Fanatics can help
I plan on using a x pipe in my dual exhaust system. My Question is how critical is the placement of the x pipe I am familiar with h pipe placements and that closer to the headers is better, but I am unsure about the x pipe placement. The engine size is a 460 and pipe diameter is 2.5 Thanks in advance Eric
Old Aug 14, 2002 | 11:52 PM
LxMan1's Avatar
LxMan1
460 x pipe
If you have duals now, the best way to determine the proper location is to paint the pipes, where ever the paint burns off first, the hottest point( not near the headers ) is where the exhaust is in need of a cross over of some kind. An H or X.
Old Aug 15, 2002 | 10:59 AM
strterl's Avatar
strterl
460 x pipe
I think it would be commen sense that the closer you go towards the headers, the hotter the exhaust is going to be. Therefore, you put the X as close to the headersa as possible.
Old Aug 15, 2002 | 11:03 AM
strterl's Avatar
strterl
460 x pipe
Old Aug 15, 2002 | 01:34 PM
merc460's Avatar
merc460
460 x pipe
I am familier with the H pipe placement and why it goes there but with the X pipe the two pipes become one pipe for about 6-8", so I was wondering that perhaps the placment of the X pipe is not as critical or one could place it futher back and acheive the same affect. Eric
Old Aug 18, 2002 | 01:08 AM
LxMan1's Avatar
LxMan1
460 x pipe
[updated:LAST EDITED ON 18-Aug-02 AT 02:08 AM (EST)]That's why I said not too close to he header collectors.
Anyway, I would put it far enough back that you can remove the tranny pan ( if it is an auto ) so that you wont be cussing later. :-X11
Old Aug 29, 2002 | 12:05 AM
trinogt's Avatar
trinogt
460 x pipe
How can you put in an 'H' or an 'X' when you have an aux. tank, and there is only room for this in the stock exhaust 'Y' location? Duals have to run up alongside the driveshaft on passenger side...
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
Old Aug 29, 2002 | 12:29 AM
LxMan1's Avatar
LxMan1
460 x pipe
you can't. Plus when you have to run them both down the same side, you have 2 different lenghth pipes so your backpressure will be a bit unbalanced from the extra bends in the longer pipe.
Old Aug 29, 2002 | 02:49 AM
merc460's Avatar
merc460
460 x pipe
I will not have any fuel tanks under the truck, so I can run the exhaust down both sides making the two pipes as equal in lenth as possible Eric
BlueOx460
Nov 9, 2016 03:03 PM
Cameo 57
Apr 26, 2016 02:14 PM
rickybobby1977
Jun 3, 2011 06:47 PM
displacement4me
Exhaust Systems
Feb 28, 2011 08:03 PM
matthew thompson
Dec 9, 2007 07:21 AM
