Changing Front Shocks
Old Jan 10, 2008 | 09:53 AM
Beefford's Avatar
Beefford
I have been mauling all week whether I want to tackle this task myself. I have read here about the need to take the spring/shock assembly to a shop and have them swap it for you. If I remember correctly from installing my leveling kit, can't you just unbolt the top of the assembly and take the shock out without any need for compressing? It has been 3 years since the leveling kit and I can't remember. Thanks.
Old Jan 10, 2008 | 11:51 AM
VegasFX4's Avatar
VegasFX4
It's a strut in the front. You'll need to compress the spring to get it apart. You can usually rent the spring compressor from an auto parts store, or a local shop could do it for you.
What you are thinking of with the leveling kit is the mounting bolts. Once you get the strut assembly out you'll need to compress the spring to remove the strut cap and spring from the strut itself. It's a fairly simple job to do, only about an hour or two in the driveway.
Old Jan 10, 2008 | 02:48 PM
MBBFord's Avatar
MBBFord
I replaced the shocks, and I think it was easier to do than the leveling kit its self was.
After more than 3 years, I'm willing to bet you have over 30K miles, and I gaurentee you those stock shocks are worn out, and aren't helping anything.
Old Jan 10, 2008 | 05:05 PM
Beefford's Avatar
Beefford
60k miles and yes the stocks are junk. Got the Bilsteins via fedex today.
Old Jan 10, 2008 | 06:46 PM
Sarge261's Avatar
Sarge261
Beefford,
I killed 2 birds with 1 stone and put the 2" adjustable struts in the front and the shocks the Bilstien kit gave me for the rear. I own my own shop so I had the tools but all in all it wasnt bad. You will need a spring compressor though. If you have a good relationship with a local shop they may do it for you. I bought new strut bearing and bushings when I did mine they were cheap too. I got them right through Ford.
Sarge
Old Sep 21, 2010 | 07:16 PM
tolliewolly's Avatar
tolliewolly
what bolts do you take off to get the front shocks off? Do you need to take the front tires off to get the whole shock struts out?
What is the proper procedure?
Old Sep 22, 2010 | 03:42 AM
svt2205's Avatar
svt2205
Please, I am not trying to be a jerk here. But if you're asking questions like this, you probably don't have much experience working with suspensions. Especially loaded coil springs, as the front struts on our trucks have. I would highly recommend that you have a local shop do this work for you.
But to answer your questions. Yes, you have to take the front tires off. And you will need a 27mm socket, a 30mm deep socket (must be a deep socket) to remove the lower bolt. And a 13mm socket to remove the 3 nuts on on the top. This will remove the hardware to allow removal of the front strut assembly.
Be careful
Old Sep 22, 2010 | 07:15 AM
Sarge261's Avatar
Sarge261
Posted in the wrong forum sorry guys my bad
Old Sep 22, 2010 | 04:09 PM
tolliewolly
Be careful
Thanks for finally answering the question.
Please in the future do not reply to my questions. I am sure this forum is for helping people and treating them with respect. Not treating them like junk.
Old Sep 22, 2010 | 07:43 PM
BatteriesNotINCL's Avatar
BatteriesNotINCL
If you guys are still working on your struts...check out my write up on changing them. I have the Daystar Level Kit Installed...Its complete with what you need and what to do:
https://www.ford-trucks.com/forums/8...ml#post7350843
Old Sep 22, 2010 | 09:39 PM
rick99601's Avatar
rick99601
some suspension components are under an immense amount of compression and can KILL you. he was just looking out.
taking off the wheel would be the first step after putting the front on jack stands and if you dont know that you shouldnt be working on the suspension. period.
he was very respectful to you, obviously you havent been on many forums to understand that.
now theres two less people to answer your noob questions. as i assume ill be asked to not reply from now on also.
buy a chiltons or haynes and use the search to avoid all this.
Old Sep 23, 2010 | 02:49 AM
svt2205's Avatar
svt2205
Trust me, I'm not wasting my time offering up anything to help you.
Old Sep 23, 2010 | 12:04 PM
tolliewolly
Great! Thank you. I am excited my time will not be wasted!
Old Sep 23, 2010 | 12:06 PM
tolliewolly
Great Write up!!!! Wealth of knowledge!
Old Oct 15, 2010 | 03:11 PM
TigerDan's Avatar
TigerDan
Wow. All I can say is wow...
