Computer Chips & Tuners
ECM application
Old Jan 9, 2008 | 11:38 AM
wild ford child's Avatar
wild ford child
Question ECM application
I have a ford ecm HUG2 F4TF-12A650-APC. How can I find the application for this computer? I had purchased several ecms (didn't label them soon enough). Is this ecm for a 1994 F150, 5.8 with mass air?
Old Jan 9, 2008 | 03:17 PM
M. Kelly's Avatar
M. Kelly
hug2
HUG2 5.0 Bronco, F-x50 E-x50 MAF / E4OD (see note 1)
Probaly more information elsewhere. That's all I have. Mike
Old Jan 9, 2008 | 03:48 PM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
Give motorcraftdotcom a try. I think under service section you might be able to search by part number.
Old Feb 29, 2008 | 11:01 AM
detrant's Avatar
detrant
will you help me? I need to know where the ECM is located on my truck and how do I know for sure that it is the problem? I have a 94 F-350 with 460 engine. The ecm is not behind the kick panel
Old Feb 29, 2008 | 04:08 PM
ReAX's Avatar
ReAX
I found a 93 F150's PCM under the drivers fender. It was a PIA, I think I was able to loosen the inner skin to remove it, but that was 6 years ago and a customers truck so I could have forgot something.
Run the self test diagnostics, I suck at EEC-IV, but there should be two harnesses under the hood, one single pin and one five pin or so. You short the single to one pin on the big harness and it will run. If you can't get diag to run, then the ECM or harness is toast. Usually if an ECM fries, the truck will not start, but a portion of the ECM could fail or short causing all sorts of problems. What specifically is happening?
Old Mar 1, 2008 | 11:26 PM
Power_Hungry's Avatar
Power_Hungry
Former ******
94 F350 should be behind the parking brake assembly. You should see the connector sticking through the firewall below the master cylinder.
Bill
Amish Ford
1997 - 2003 F150
Dec 4, 2015 05:11 PM
gman97005
May 21, 2015 06:11 PM
302Meister
Feb 3, 2015 02:16 PM
GuitarJesus
Oct 21, 2014 05:22 PM
erikkloss
6.4L Power Stroke Diesel
Aug 10, 2014 08:39 PM
