Sponsored by: Auxito
ECM Location
Old Dec 4, 2015 | 04:13 PM
Amish Ford's Avatar
Amish Ford
ECM Location
I need to replace the ECM on my 2002 F150 (5.4). I have NO idea where it is. Help! I need the code off of it so I can get the correct replacement.
Old Dec 4, 2015 | 04:39 PM
Bluegrass 7's Avatar
Bluegrass 7
You cannot just replace it unless proven faulty.
It will need to be reprogrammed and keys reprogrammed.
The Theft, dash and PCM all have to be done so they communicate with each other.
If not, you will never start the truck.
This is how the Theft system works.
Why do you want to replace it?
With out this info you will just get deeper into problems.
Good luck.
Old Dec 4, 2015 | 04:43 PM
Amish Ford's Avatar
Amish Ford
Yeah....I know all that! The system has been checked out, and the ECM has been determined to be at fault. What I need is the number off of the ECM so I can get a new one, then take it to the local Ford dealer to install. All I need is where to look....
Old Dec 4, 2015 | 05:11 PM
Bluegrass 7
We are always skeptical here of some one else's diagnostics without hearing the details.
Our advice is free.
The PCM is behind the passenger kick panel.
I hope you correct.
Good luck
johngeorge
Sep 18, 2020 10:59 PM
jcrunk808
Oct 2, 2015 01:05 PM
noplugs
Apr 8, 2011 09:04 AM
200154tritonguy
1997 - 2003 F150
Jun 22, 2010 01:45 PM
estradaboi
1997 - 2003 F150
May 1, 2010 06:36 PM
