ECM issues
Old Feb 2, 2015 | 03:53 PM
302Meister's Avatar
302Meister
Question ECM issues
Looking for an ECM for my 87 F150 5.0 C6. Anyone have one for sale? I have the serial number
Old Feb 2, 2015 | 04:17 PM
rla2005's Avatar
rla2005
Why do you think you need a replacement computer?
Old Feb 2, 2015 | 04:18 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
How about that? Something I actually have. I'm quite a ways away. Looks like you are in Florida?
Checked rates, I can send it expedited parcel for about $30. 6-7 days delivery. Give me another $20 for the part and packaging and I'll send it your way. $50 total.
edit
And yes, why do you need one? This one came from a running 5.0 87 truck. I'll check caps before I would send it.
Last edited by NotEnoughTrucks2014; Feb 2, 2015 at 04:21 PM. Reason: see above post!
Old Feb 3, 2015 | 10:06 AM
NotEnoughTrucks2014
Things became clear.
https://www.ford-trucks.com/forums/1...ease-help.html
302meister, if you want the ECU, I can send, but you really would be better off looking for one locally. Wreckers usually want around $25 for them at a U-pull.
I'll go back to the other post and try to help.
Old Feb 3, 2015 | 01:45 PM
302Meister's Avatar
302Meister
I found a reman ECU locally for 75 bucks with lifetime warranty. I think its an ECU problem because I've replaced every ignition and fuel component i can think of. I have plenty of compression. It isn't firing right. I've checked my firing order, replaced plugs &wires, cap and rotor button, replaced ignition coil, and checked timing
Old Feb 3, 2015 | 02:16 PM
rla2005's Avatar
rla2005
Checked the timing with the SPOUT out?
Just because the vacuum lines may be connected to the right place means nothing. Those 20+ year old vinyl tubes fall apart if you look too hard at them.
Have you tried pulling the Codes from the Key On Engine Off (KOEO) tests and stored aka Continuous Memory (CM) display?
Before plunking down $$ for no reason, at the very least pull your computer (PCM) out and inspect it for leaking capacitors or burn spots.
duerj70
5.0L Coyote
19
Jul 1, 2021 12:27 AM
Jack Dressler
Jul 13, 2016 08:50 PM
Holehawgg
May 28, 2013 02:00 PM
kalawikimaui
Jun 28, 2008 06:41 AM
rcav8or
Jan 10, 2008 02:54 PM
