lube
Old Jan 8, 2008 | 11:29 PM
bigdaddy54's Avatar
bigdaddy54
lube
i never thought about it till now....are there any zerks under the truck to be lubed at oil changes??? if so does anyone know approx how many and what kind of grease do you all recommend? thanx
Old Jan 8, 2008 | 11:36 PM
zrt600guy's Avatar
zrt600guy
I don't think there are any, but I could be wrong!
Old Jan 8, 2008 | 11:47 PM
bigdaddy54's Avatar
bigdaddy54
yea ive only done 2 or 3 oil changes and never saw any but i wasnt looking so who knows
Old Jan 9, 2008 | 12:00 AM
tippmann87's Avatar
tippmann87
I asked my dealer when I was there once.......nothing to lube under the truck except for 2 spots near the front axle
Old Jan 9, 2008 | 06:18 AM
blockmanjohn's Avatar
blockmanjohn
My '06 only has two. One at each front driveshaft universal.
Old Jan 9, 2008 | 11:04 AM
thedaddycat's Avatar
thedaddycat
My '03 has a couple on the steering linkage, one at each end. Those were the only two I saw when I serviced the front hub needle bearings.
Old Jan 9, 2008 | 11:27 AM
4x4Mark's Avatar
4x4Mark
There are 4 on the pre-05 trucks - along the steering linkage.
Mark
Old Jan 9, 2008 | 12:12 PM
Storm's Avatar
Storm
Steering linkage is the only zerks.. Everything else must be done by hand which is easy..
4WD Hub
  1. Squeeze snap ring and remove.
  2. Pull Locking Hub out
  3. Clean Axle Shaft Splines and Hub Splines
  4. Apply LIGHT LIGHT LIGHT coat of Synthetic Grease (do not apply a ton, too much grease will damage the Hubs)
Rear Axle Slip Joint
  1. Remove Axle from U-Joint clamps (be sure to mark orientation with chalk, paint)
  2. Gently use needle nose pliers and spread the metal clamps (if done properly you can reuse them, no need for Zip Ties)
  3. Remove Axle side of drive shaft slightly from the slip joint. Use a punch tool and make a small mark to note alignment. Use the blue Teflon Shaft as a point and the Metal Housing of the Transmission side Shaft to mark.
  4. Clean Teflon Shaft and inside of Slip Joint on Transmission side Axle
  5. Apply a nice amount of Grease (Schaffers, think thats how it's spelled, makes some DAMN GOOD lube. I used their Red Tube and so far my shaft hasn't made a single knock. By now the Ford stuff would be gone and I'd have the clunk).
  6. Align shaft into Slip Joint and slide back in. If using Schaffers you will have a lot of resistence.. Just work it in and out (quit thinking dirty!) to get the lube in every spline.
  7. Slide rubber boot back over Slip joint and apply the metal clamp. You will see two hooks on the end of it, slide it onto those hooks and compress the clamp point you spreaded in Step 1.
That's about it as far as oil interval maintenance. Spread it out over X number of miles you seem fit. Other points to lube are the Caliper Slide Pins, and the Tie Rod/Drag Link ends.
If I left anything out please add to it..
Old Jan 9, 2008 | 03:44 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Mine has aftermarket ( I guess) greasable lower BJ's and also u-joints on the rear DS
Old Jan 9, 2008 | 04:11 PM
rollerstud98's Avatar
rollerstud98
check your uppers, might just have a removeable plug in them, thats what i had to do with mine as the u-joint did not have enough clearance space,
Old Jan 9, 2008 | 04:29 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
I'll have to check that, thanks!
Old Jan 10, 2008 | 06:57 PM
paddler65's Avatar
paddler65
a good question
i own an 05 f-350 4x4 cc drw and havn't found any grease fittings. have i over looked them?
thanks for much inf.
Old Jan 10, 2008 | 06:59 PM
Storm's Avatar
Storm
There are very few grease zerks on the SD period.. Only ones I physically know of are on the Steering Linkage.. Everything else is pull a plug or disconnect and lube.. Or they are non-greasable parts.
51FordTN
May 20, 2013 06:57 PM
bigred66
Jun 8, 2010 09:11 AM
Ford Truck Racer
Sep 30, 2002 10:20 AM
rebocardo
Aug 18, 2002 09:24 PM
FTE Ken
Jan 2, 2002 04:16 PM
