Trans question?
Old Jan 8, 2008 | 08:47 PM
Truxx1956's Avatar
Truxx1956
Question Trans question?
Hey guys, I KNOW this is the wrong place, but I like you guys better. My question is about my M5OD in my 1989 F150. I told you that I bought this truck with the trans locked up, cause it had been run with NO trans oil. I might have found a "good" used one? My question is: Is there any way at all of checkin this thing before installing it? I know I can check and see if it has oil in it, and move the shifter into the gears, but other than that is there anything else I can look for?
Thanks guys!!
Old Jan 8, 2008 | 09:21 PM
sdetweil's Avatar
sdetweil
You can drop the pan and check for burned fluid, or parts, change the filter. Hard to tell if the plates are burned up tho.
Ah, its a manual.. check the fluid for parts..
Sam
Old Jan 8, 2008 | 09:30 PM
51dueller's Avatar
51dueller
You can take the shift tower off the transmission and then visually inspect the gears.
mechmagcn's Avatar
mechmagcn
Sam
This is a 5 speed manual trans. I would drain the fluid and check for any metal shavings in it, this should give you an idea of condition.
Old Jan 8, 2008 | 10:31 PM
Fomoko1's Avatar
Fomoko1
If it has a magnetic drain plug it`s a good place to also look for filings.
Old Jan 8, 2008 | 10:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If it doesn't shift into all the gears easily now, it won't later. (you may need to rotate the input shaft a little while shifting)
Old Jan 8, 2008 | 10:56 PM
havi's Avatar
havi
I'll have the Roast Duck
Sam
Or check the parts for fluid.
On top on the back, I think are leaking points, they have a fix for that. secondly, I'd check the integral hydraulic clutch hose for cuts or kinks, cuz the whole tranny has to be dropped to get to it, so might as well make sure ahead of time that it is good.
Non removeable bells are a PITA.
Old Jan 9, 2008 | 07:27 AM
Truxx1956's Avatar
Truxx1956
Thanks guys! I'm goin to get it soon! Havi, I'm definately goin to check that hose, and also I'm goin to change the rubber plugs to steel freeze out plugs to eleminate the shifter rail leak.
Thanks again
TheNomad
Oct 8, 2014 05:48 AM
jabkoV8
Sep 4, 2012 07:04 PM
AGE mechanic
Jun 23, 2012 10:09 PM
nobearsyet
Jan 6, 2012 02:16 PM
Vijay
Oct 7, 2009 05:23 PM
