'51 4-speed tranny question
Old Jan 7, 2008 | 07:04 PM
rcav8or's Avatar
rcav8or
If you use it, SUPPORT IT
Has anyone gone through one of these tranny's? When I pulled mine, I set it down nose-down, and it leaked oil all over the floor. So I'm assuming front seal? All the pics I have seen, show a bearing, is that a sealed bearing? Tough to get out and replace? Inquiring minds, want to know...
Thanks,
R
Old Jan 7, 2008 | 08:50 PM
havi's Avatar
havi
I'll have the Roast Duck
if it's like my t18, when you lean it forward, the input shaft with bearing will slide out if pulled hard enough.
Old Jan 7, 2008 | 09:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The parts manual doesn't list a seal on the input shaft, just a slinger.
Old Jan 8, 2008 | 09:05 PM
rcav8or's Avatar
rcav8or
Yeah, just a slinger is what it looked like in my feeble drawing. If that's the case, wouldn't it be likely that it would eventually leak, if left standing on it's nose? I mean, the oil might work it's way out?
I really don't want to tear into the tranny if I can help it. But, I am concerned that the oil could get into the clutch, although when I took it apart, there was NO evidence of oil in the bell housing.
Thanks again,
R
Old Jan 8, 2008 | 09:12 PM
rcav8or's Avatar
rcav8or
{edited}Ooops....duplicate post! FoMo, please erradicate this post?
R
Old Jan 8, 2008 | 10:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Even with a seal, if stood on end it would eventually leak out. I don't think you have a problem. You might want to take off the retainer and clean it out before using it.
Old Jan 8, 2008 | 11:27 PM
bobj49f2's Avatar
bobj49f2
They most likely didn't design the tranny to sit on it's nose so they might not have worried about it leaking. As long as the tranny gear lube fill line was below the input shaft it won't leak. I am pretty sure all of the trannies I have taken out of the parts trucks I have had leaked if I let them rest on their sides.
Old Jan 8, 2008 | 11:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Hell, mine leaks while in the truck!
Old Jan 8, 2008 | 11:36 PM
bobj49f2's Avatar
bobj49f2
Heck, we all start leaking something when we get over 50 years old!
Old Jan 8, 2008 | 11:40 PM
rcav8or's Avatar
rcav8or
Thanks, all! Guess I've never set a tranny on it's nose before! Every one I have ever done has been out, rebuilt, in. Even in the old days of working on the British cars, they'd be drained first, before storing.
I'll surely clean everything I can, before it goes back in.
R
Old Jan 9, 2008 | 07:42 AM
HOTWRENCH's Avatar
HOTWRENCH
Talking Tranny Leaks
The old trannys didn't use a seal on the input shaft they used what is called a labryinth seal. Nothing more than a threaded section of the input shaft that directs the oil back into the case. The threads work like an auger and pull the oil back . It's inportant not to overfill these trans as they will leak when not running. It's also important that the bearing retainer be clear of sealant and the gasket is positioned correctly so the drain hole is open. Try not to park your truck with the nose severly downhill as there is the possibility of getting gear oil on the clutch.
Have A Good Day----Hotwrench
garydmundy
Jul 3, 2013 12:22 AM
low92flareside
Mar 7, 2006 09:45 PM
aging_F150
Oct 8, 2004 09:05 AM
Whitty
1978 - 1996 Big Bronco
Dec 14, 2003 02:20 PM
