351w stroker CR
Old Jan 27, 2008 | 01:25 AM
  #31
Redtires019's Avatar
Redtires019
sorry, I didn't see that
4.060 bore
3.85 stroke
H273CP pistons (book shows 8 cc's in valve reliefs)
.018 deck clearance.
Adding in a felpro 1011-2 gasket (.039 compress thickness x 4.1 bore) I get the following
60 cc heads - 11.177
64 cc heads - 10.693
68 cc heads - 10.254
72 cc heads - 9.853
Refigured with Felpro gasket # 1134 - (.041 compressed thickness, 4.18 bore) I got it to drop slightly a little bit
60 cc heads - 11.078
64 cc heads - 10.604
68 cc heads - 10.173
72 cc heads - 9.778
Refigured again with Felpro gasket # 1137 (.053 compresed thickness x 4.21 bore)
60 cc heads - 10.734
64 cc heads - 10.291
68 cc heads - 9.886
72 cc heads - 9.516
It averaged out to .25 more compression with the .060 overbore.
Here is a link to the program I am using. the page discusses Dynamic compression and its importance. The program figures both Static compression and dynamic compression. Look near the bottom of the page for the program link. http://www.empirenet.com/pkelley2/DynamicCR.html
Old Jan 27, 2008 | 11:10 AM
  #32
Wreckit87's Avatar
Wreckit87
whoa buddy where are you coming up with almost 12:1? I thought we decided it was like 11.2:1.... ? I see you're not a huge fan of the high CR but I built a 351W last year for one of my buddies and it ended up like 10.4:1 with iron D0OE heads and he's got about 5000 miles on it and he drives it HARD without any problems. Just doesn't like to start when its warm lol.
Old Jan 27, 2008 | 11:35 AM
  #33
HemiEater's Avatar
HemiEater
What cam or should I say what rpm range is this motor going to be run at.... get that figured out and then build the motor with the recommended compression givin by the cam for that rpm range. If the motor is going to spin 5000 tops then you might want to keep the compression down to near stock.... but if your spinning it to 7500 you might want to run say 11to1
all depends what the cam manufacture recommends for compression...
Ive had a few friends and myself for that matter build motors with to much compression. only thing you can do to correct it is run bigger cams or rebuild it to a lower compression. Plus the cost of fuel these days..... anywhere around 8.5 to 9.5 would be where I would shoot for....if it's a daily driver on cheap fuel with a small torque cam....
Old Jan 27, 2008 | 06:58 PM
  #34
doug1222556's Avatar
doug1222556
Hey Wreckit87, I don't know where I came up with 12:1 either. Still think you might want a lower CR, though. Have you gone to the link Redtires019 left on the bottom of reply #31? That's some interesting stuff that I'm going to look into further when I have more time and energy. It's something I had never heard of but makes a lot of sense and could really help me with my cam choice (I have 2 already). It would probably help with yours, as well as whether to run with your present anticipated CR.
Old Jan 28, 2008 | 02:00 AM
  #35
HemiEater's Avatar
HemiEater
it all has to match.....
Old Jan 28, 2008 | 11:08 AM
  #36
Wreckit87's Avatar
Wreckit87
no i haven't yet but i will. Actually i found a set of AFR 185's yesterday with 72cc chambers!? and he wants like $900 for them so i think ill just go that route. I ran the #'s and came up with 9.9:1.... Perfect.
70FE250
51
May 12, 2017 03:09 PM
doncoyote11
Mar 3, 2004 10:11 PM
Brian460
Jan 7, 2003 11:31 AM
black angel
22
Jul 22, 2002 04:19 PM
black angel
16
Jul 14, 2002 06:06 PM
