what is needed to switch a 351m with a 4 spd in a 78 f150 to a 460 out of a 74 lincoln. will the 460 crank be drilled to accept a pilot bearing. are the mounts the same and the flywheel. exhaust i'm not worried about. can the car oil pan be used in the truck.
