Headlight bulbs
Old Jan 6, 2008 | 07:18 PM
97 HD's Avatar
97 HD
Headlight bulbs
I lost my drivers side low beam today. I was wondering what yall reccomend as far as a good bright bulb. NONE OF THOSE CHEESEY BLUE ONES. The ones that are in there are good and bright I dunno what they are though the PO installed them.
Old Jan 6, 2008 | 07:57 PM
IDMooseMan's Avatar
IDMooseMan
I use NAPA replacement bulbs. I don't recall if they're labeled as "Bright" or anything. They have an OEM replacement and a brighter version. I use the brighter version. I have no problems with them.
I can't remember what it's called, but there is a headlight upgrade that is available. I believe it increases the amount of amps or volts available to the headlights, creating a brighter beam.
Old Jan 6, 2008 | 08:16 PM
tjbeggs's Avatar
tjbeggs
Napa carries Wagner Trueview bulbs. They seem pretty good. They do have a blue coating but don't look blue in the headlights or light color. Also what Craig said is true about the mod. The stock wiring going to the headlights is too small and doesn't allow full voltage to the bulbs so the mod has two relays and heavier wiring to bring more voltage to the bulbs. I have tested this with jumper wires and there is a noticeable difference look at the lights. Not sure about driving but every bit helps
Old Jan 6, 2008 | 08:19 PM
tjbeggs's Avatar
tjbeggs
here they are. bottom of the page
http://www.lmctruck.com/icatalog/fd/0057.asp
Old Jan 6, 2008 | 08:20 PM
IDMooseMan's Avatar
IDMooseMan
Thanks for the confirmation, TJ.
Old Jan 6, 2008 | 10:05 PM
c00nhunterjoe's Avatar
c00nhunterjoe
and for headlight bulbs hit walmart for the....crap they are from sylvania....i thnk they are called xtravision? i will check my box tomarrow, they are the same part number as the regular bulb with one extra letter on the end..... i think its an x? but they are a lot brighter then the stock ones and last a long time and are only a dollar or 2 more then a stock one
Old Jan 6, 2008 | 10:17 PM
powerstrokeddiesel's Avatar
powerstrokeddiesel
the best buld without doing the hid conversion is silverstars...
Old Jan 6, 2008 | 10:19 PM
dabears2k's Avatar
dabears2k
The HID conversion is really not that hard. The silverstars are known to burn out quickly and are expensive. The HIDs will outlast the truck.
www.dabears2k.com
Old Jan 6, 2008 | 10:26 PM
F0rdF0rever's Avatar
F0rdF0rever
Do you need the optional wiring harness as well as the kit? And whats the difference between the different wattages? Thanks.
Old Jan 6, 2008 | 10:38 PM
powerstrokeddiesel
the hids you have to put in another relay to supply the power the hids need... as for me the silverstars have been in my truck for going on a year now... and they are fine... but that is just me.. and the hids i have heard of ppl getting tickets for them being to bright... but it is your pick...
Old Jan 6, 2008 | 10:46 PM
Robbgt's Avatar
Robbgt
[QUOTE=powerstrokeddiesel]as for me the silverstars have been in my truck for going on a year now... [QUOTE]
Another vote silverstar here...
-Robb
Old Jan 6, 2008 | 10:56 PM
c00nhunterjoe
cars flash at me already with my headlights, i cant imagine going much brighter!
Old Jan 6, 2008 | 10:58 PM
powerstrokeddiesel
ahh between my fog lights and silverstars drivers almost pull off the road and stop when i am coming...
Old Jan 6, 2008 | 11:00 PM
c00nhunterjoe
just add one scopp of train horn and they'll wreck too!
Old Jan 6, 2008 | 11:05 PM
powerstrokeddiesel
train horns are on my list to be next... i want horns loud enough to make ears bleed... hehe...
