engine i.d !!!have casting numbers!!!
Old Jan 6, 2008 | 04:18 PM
crescentwrencher's Avatar
crescentwrencher
ok ive got an f250 4x4 hiboy
passenger side head number: c4ae
drivers side head number: c4aeg
block number : 05aza
hope this helps!
Old Jan 6, 2008 | 04:23 PM
STGFordCrazy04's Avatar
STGFordCrazy04
360FE was the only engine offered in 73-77 F250 4x4s. The bad thing is that 390s share the same block and heads and are impossible to determine visually from a 360. The only way to tell without disassembling the motor is pull a spark plug with the piston at BDC and use a CLEAN dowell or something to measure the length. Post your findings.
That block number is 99.999% C5aza not O5aza.
Old Jan 6, 2008 | 04:44 PM
crescentwrencher
the only unexplainable thing is it has merc valve covers, so im not sure if its the original engine.heres a pic
Old Jan 6, 2008 | 04:49 PM
STGFordCrazy04
Thats deffinately a FE engine. 360 390 410? Very tough to say. Merc used 390s and 410s in the mid 60s (C4 and C5 part numbers) 360s were factory and were only offered in 73-76 Ford trucks I think.
Without checking a smart man would say 390. Ford made millions of them and they were cheap. It was also a very common swap.
Old Jan 6, 2008 | 04:51 PM
crescentwrencher
it has a 2v carb on it i doubt its anything bigger than a 390
Old Jan 6, 2008 | 04:59 PM
STGFordCrazy04
very true they did have 4bbl intakes/carbs. I doubt it would be a 410 anyway because from what Ive seen they are quite rare compared to 390s
Old Jan 6, 2008 | 06:04 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You have yourself a 352 or 390 judging by a C5 casting code. Gotta measure the stroke.
Josh
Yahiko
Dec 10, 2012 06:14 AM
ehgeeray
Nov 23, 2010 09:13 PM
hbpaints
Aug 7, 2010 11:38 AM
abelmoreno
Sep 17, 2007 06:57 AM
carlos694x4
Nov 11, 2000 01:27 AM
