Yes I do remember those commercials and the high gas mileage ratings. The EPA tests were actually performed for emissions and done on a dyno. A city cycle and highway cycle were part of the test and mileage figures were published for comparison with other similar vehicles. I don't think air or rolling resistance were factored in. IIRC the highway cycle was set at 49 mph.
Still one of the best looking trucks ever made !
regards
rikard
ive gotten a best of 23 mpg in mine, and i had many things holding me back.
First and foremost, im carb'd and without overdrive. secondly, the overall condition of my truck wasnt at its best.
i cruised 70-75 the whole way, which is 2500-2700 rpm for me. im sure if i was closer to 2000 with fuel injection and newer odds and ends (like repacked wheel bearings, etc) i could have gotten high 20s.
I also remember seeing that commercial on TV. If you read the fine print you will see that it says "Actual Hwy mileage and California rating are lower".
Back in the days when those truck were being built I would say that 30mpg was possible, but not in a truck you'd want to drive. The didn't load them up with frivolous crap like they started doing on the later body styles. It would have to have the tallest possible rear gear, no power anything, no AC, no P/S, no electical accesories and driving at 55 mph with a tailwind. In other words, the engine wouldn't turn anything but the wheels and alternator. If it didn't come with a radio it wouldn't have an antenna, and a passenger side mirror might have been an option then as well. All the little things add up. All that stuff also adds up to a few hundred pounds that it doesn't have to lug around.
Sounds just like my Bronco! Except I do have to admit I have an antenna. =P
Correct me if wrong. I remember talking to a guy who had a Ford from those years with the inline 6 and OD manual transmission. He said the 4th gear OD was so high is was useless for him. So maybe in flat country it might get mid 20s mpg? In the ad it mentions a transmission option.
That's what mine's like. I6, 3.00 rear end, 4 speed manual with OD. Fourth gear is really really high and I can only really use it if I'm going over 50mph and am not climbing any hills. However, in the flats, I can coast at 75mph at 1700 RPMs and it does get in the low 20s if I keep it around 65 (probably will do even better when I put a new exhaust without a clogged cat on it.)
Yeah, the ad mentions the 4spd O/D manual trans. When mated to a 4.9L engine, and backed by the 2.75-3.00 rear gear ratio, they can acheive in excess of 20 MPG. The engine is at such a low RPM, they don't have much usable power in 4th(O/D) though. Also not that good in hilly terrain, nor for pulling a trailer.
This combo works rather well, when used with a 3.25 or lower (higher number) rear gear ratio.
The engine/trans/rear gear combo was used as a MPG leader, but wasn't that useful for people who actually work their trucks. Same holds true for the later EFI 4.9L/5 speed, backed by the 2.73 rear gear. Killer MPG on the highway empty, but not much power for working.
I remember those ads. My dad was a die hard Ford man and had many half & 3/4 ton pickups for his company. All were 6 cylinders and I never remember him having a problem with any of them mechanically. Too bad I can't say the same thing about rust.
I can't view that here at work. Is that the one where the truck jumps off a ramp and does a roll into a big net in a ditch and on the underside of the truck is the MPG in big letters? I didn't remember that one being 30 but hell it was about 25 years ago.
Jass88, the commercial shows two pickup trucks of different colors (one blue, one tan) driving side by side driving straight at the camera, over one it says "Highest MPG", the other one, "Most Powerful Six". Then they swerve into each other and become the same classic Ford red truck. After that the truck just drives to the top of a hill and it has some gas mileage information superimposed over it about it getting 30mpg and 20mpg ave. highway. Fade out to a "Built Ford Tough" logo and end of commercial.
Then there is another one out there because I distinctly remember the one I am describing, it would have been about 83-84, the truck was a red short bed F100.
I remember that commerical, and I have a few old car magazines that show those EPA figures. In the early 80s they were pushing fuel economy as much as they are now.
I get about 18-19 in my '80 F-100 @70 mph with three speed no OD, primer, no power acc. The truck has oversized tires and a 2.73 rear end. My father got 26 (55 mph) in it when it was new.
