serpentine conversion 460
Old Jan 4, 2008 | 05:01 PM
tweaker's Avatar
tweaker
I have a 1981 F-250, with a 460.
For some reason, after the rebuild my power steering pump hits the steering box at an idle (lumpy cam, makes it quite annoying, bang bang bang bang)
I have been toying around with the idea of switching to serp. setup. I found all the parts from a 1993 f-250 460,
Will they bolt right up ? Timing cover differnces ?
I'm pretty sure i have to go with Elec. fuel pump, Which is fine, becuse my eccentric is making funny noises, and now the neighbor has it in there back yard.
Thanks for all the help and input !!
Nick
Old Jan 5, 2008 | 12:14 AM
Franklin2's Avatar
Franklin2
The waterpump will be different. A serpentine waterpump turns backwards. Will a shorter belt fix the problem you have now?
Old Jan 5, 2008 | 01:37 AM
tweaker's Avatar
tweaker
Frank,
The power steering pump is all the way in, sucked up against the water pump(as far as it can go anyways)
I don't see how the water pump would turn backwards, The belt is setup the same way my setup is now, or at least i think it is.
Would it hurt if i ran the other way ? I planed on buying a new serp. water pump any how, does it reverse the flow ? or just have a diff. impeller ?!
Thanks
Nick
Old Jan 5, 2008 | 02:43 AM
Sycostang67's Avatar
Sycostang67
The routing of the belt causes it to turn the other way, so the impeller is reversed so it still functions properly. I knew the serp'd 302's were that way, but didn't know the 460's were the same. My friend shattred the PS pulley on his 4.0 ranger, and had to use a shorter belt and different route that caused the pump to turn the wrong way. He said it never overheated, but his fan made a lot more noise.
Old Jan 5, 2008 | 03:09 AM
tweaker's Avatar
tweaker
From what i was looking at the belt is routed the same way.
I can't find any full pictures of the diagram so i can tell which way.
I understand the whole waterpump backwards will cause the fan to push instead of pull. but i'm going electric any way,
Old Jan 5, 2008 | 05:16 PM
Franklin2's Avatar
Franklin2
A v-belt goes around the pulleys, with the belt driving on the same side on all pulleys. So they all turn the same direction, if the engine turns clockwise, the the alt, waterpump, power steering, etc., will all turn clockwise.
With most serpentine systems, the waterpump pulley is smooth, and is driven by the backside of the belt. So it turns the other way. If the system you are looking at does not run the waterpump on the backside of the pulley, then you should be ok with the original pump.
Old Jan 6, 2008 | 07:35 AM
tweaker's Avatar
tweaker
So in theroy, if the setup i'm looking at were smooth, the pump would need to be replaced with a EFI pump correct ?! For it has a reversed impeller
Should every thing bolt up ? timing covers the same and all ?!
I'm alos doing the 3G swap on this truck, So the brackets should make it a better fit right ??
Thanks for the help !
Nick
Rockyroger
16
Jun 4, 2015 04:06 PM
des.eli.anthony
Sep 26, 2011 07:33 PM
68 ranger
Oct 22, 2008 05:41 PM
norfolk-southern
Mar 21, 2005 06:38 PM
ItzKwik
19
Jan 26, 2004 12:44 PM
