6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Boost pressure
Old Jan 2, 2008 | 04:33 PM
hunt2r's Avatar
hunt2r
Boost pressure
What kind of boost pressure are you seeing. On the interstate running 65-70 I am seeing about 20-25 and if I encounter a grade it goes up to around 30. I am curious as this seems high compared to the 6.0. I know this engine is totally different. I have a F-350 DRW 4X4 6.4 PSD auto 3.73
Old Jan 2, 2008 | 05:12 PM
jam105's Avatar
jam105
I'm about the same..Some folks talk about keeping the boost under 10 for mpg...I can hardly get my F-450 up to speed without going 20....
Old Jan 2, 2008 | 05:19 PM
hunt2r's Avatar
hunt2r
Thanks. I have no idea how they are keeping the boost that low.
Old Jan 2, 2008 | 05:29 PM
kawtiper's Avatar
kawtiper
I have a 250 with the same rear end as you w/20" rims. When the beast is cold it wont get out of its own way under 10lbs of boost. warm it does ok but is usually a little over 10lbs. 65 or 70 no problem under 10 lbs until a good incline then it goes up. cant say I have seen over 28 but have not towed the toy hauler yet.
Old Jan 2, 2008 | 05:50 PM
10000LBS's Avatar
10000LBS
When I run my truck in the mountains of British Columbia I would see the boost gauge go up as far as 35 psi and on the down slopes to about 1 psi. I figure if I am going to blow the turbos then so be it.
Old Jan 2, 2008 | 05:55 PM
fordfish's Avatar
fordfish
Me too, I have tried to take off under 10 lbs, but it takes 5miles down hill to stay under 10. 20-25 at 65-70 seems normal.
Old Jan 2, 2008 | 05:59 PM
hunt2r's Avatar
hunt2r
Thanks guys. This is my 8th ford diesel truck and this is the nicest one yet. I have my fingers crossed that this one is as dependable as the others. I have not had a bad one yet.
Old Jan 2, 2008 | 06:02 PM
SUPERDUTY_untouchabl's Avatar
Theres a few people that have pegged the boost guage on here stock. My dad has seen 39-40 psi on his he said there was just a hair of black between the needle and the 40 psi mark. He said he had to look hard to acualy see it.
Old Jan 2, 2008 | 06:40 PM
PSD6litre40's Avatar
PSD6litre40
I have pegged mine pulling the mountains between NC/TN (The Smokys) pulling about 15K
Old Jan 2, 2008 | 06:48 PM
kawtiper's Avatar
kawtiper
I guess we just have more air to start with here at 0 feet in elevation.
we can get the job done with less boost.
Old Jan 2, 2008 | 07:04 PM
You were one of the ones I was reffering to.
Old Jan 2, 2008 | 07:46 PM
lucky7's Avatar
lucky7
When I bought my truck in the summer, I could cruise at 70 mph and see 10 psi of boost pretty consistently. Now that the temps have tanked, I see more like 15 to 20 psi of boost. My gas mileage has also decreased in the cold weather along with the increase in boost pressure. Just one more reason I can't wait for it to get warm again. The older I get, the colder I get.
Old Jan 2, 2008 | 07:57 PM
Sayonara's Avatar
Sayonara
avg 10-15 at ~70 unloaded. terrain and load changes the numbers...
Old Jan 3, 2008 | 07:35 AM
PSD6litre40
Also, I am pulling that same grade with my 6.0 w/ a tow tune wide open to maintain 65 MPH. The 6.4L doesn't even struggle I can slow down and gain the speed right back with the 6.4! Oh yea, at 40+ PSI those twins are screamin!
Old Jan 3, 2008 | 12:57 PM
luke1213's Avatar
luke1213
my boost pressure is wierd. sometimes it stays around 20psi when cruising. i have seen it as high as 40 not pulling anything and doing about 80 mph on the freeway. one day it hovered arounf 35 psi for about 2 1/2 hours. i asked ford about this and they didn't have an answer. turbo bearing will probably be the next thing to go out on this truck.
lakewood
13
Jan 17, 2020 04:14 PM
LSO1123
13
Dec 1, 2011 11:16 PM
wbhinton
Apr 25, 2006 06:47 PM
crapr6
31
Oct 17, 2005 03:37 PM
jamesj
May 16, 2005 09:45 PM
