Turboed 300L6?
Old Jan 1, 2008 | 09:56 PM
Grey89F250's Avatar
Grey89F250
Turboed 300L6?
Who has done? How hard you think it would be? I will be using an EFI engine.
Old Jan 2, 2008 | 10:43 AM
AbandonedBronco's Avatar
AbandonedBronco
Sadly, the fact that you have an EFI engine is going to make your workload to turbo the engine increase by a hundred fold since you'll have to deal with making the computer happy. If it were carbureted, it's much much easier. However, that's not to say it can't be done. There's a guy on there that is running a 12 sec. 1/4 mile with his 77 pickup 300I6.
Keep in mind that it's going to be almost 100% custom work, there are no kits. However, the plus side is that there is a good amount of room around the 300, so you don't have to squeeze everything in.
Check out the tech info at www.fordsix.com under the Turbo/Supercharger/EFI Tech forum. Here's a direct link:
http://fordsix.com/forum/viewforum.php?f=22&sid=3e420c06a968fb85542691330a3 21102
Old Jan 2, 2008 | 11:17 AM
Silver Streak's Avatar
Silver Streak
It won't be harder with EFI, it will probably be easier.
Others have done it, the search function is your friend.
Old Jan 2, 2008 | 11:21 AM
AbandonedBronco
Easier? Why do you say that? I've looked into it quite a bit and I've heard that turboing a carb engine is just a matter of beefing up the engine, fabbing up a turbo setup, and tuning the carb to accommodate, whereas I've heard nothing else than turboing an EFI is a computer controlled nightmare.
Might be wrong, but wouldn't want to give false hope where it's not due.
Old Jan 2, 2008 | 01:59 PM
Silver Streak
Because it is easier. All of the fabrication is going to be roughly the same amount of effort for either one, the only difference will be the tuning. With the carb you've got to jack with everything on it to get it running right, and then do it again when the weather changes. With EFI all you have to do is install an FMU and you're done. It doesn't get any easier than that.
Old Jan 2, 2008 | 02:17 PM
Grey89F250's Avatar
Grey89F250
True. I dont think the carb is as sensitive when you have forced induction on it. The carb design changes alot when you have to go to a blow through design carb. EFI would still be easier to drive and work with once its all said and done. Im not planning on doing this either. Just wondering if any had done it.
Old Jan 2, 2008 | 04:29 PM
SR_Crewchief's Avatar
SR_Crewchief
SS I'm going to have to disagree with you on this one. An FMU, by it self, isn't all that is needed to turbo our EFI 300's. Specifically ignition timing isn't being addressed. And manually retarding base timing is going to cause other issues.
Now if you know of someone that has cracked the 300 SD tables and has coding to adapt a 2 bar (or 3 bar if your looking for more than 15psi of boost) MAP sensor into the equation, then an FMU shouldn't even be needed. The problem there is that appearently the Ford SD code doesn't properly handle VE calc's that exceed something like 95%.
There are some aftermarket ECU's that might be able too be swapped. Like the latest one from Accel DFI that I read about last fall. But your looking at a minimum of $1200 for the ECU and harnesses.
But I've yet to find an example of someone just using an FMU and having a host of trouble that eventually killed the engine. YMMV
Old Jan 2, 2008 | 05:22 PM
Silver Streak
If you remember a thread from a few weeks ago you know that I am the first to say that the EFI 300 has some shortcomings for high boost. However, if you run modest boost, maybe 6-8 psi, I believe it is doable. You can buy an ingition box (like this one)with a build in boost retard and overcome the timing problems easily, which is something you would have to do on a carbed engine anyway. If I had to pick an engine for everyday driveability, durability and efficiency I would choose a well built naturally aspited 300 any day of the week and twice on Sunday. His question was how hard would it be, to which someone replied that carbed would be easier. I believe that is false because it is so easy to overcome the limitations of the computer.
Old Jan 2, 2008 | 06:52 PM
SR_Crewchief
October if I recall correctly.
I'll agree that with a boost referenced FMU AND a boost referenced ignition controller you got a chance with low boost. Especially if you have wideband to help dial everything in.
My issue was with "With EFI all you have to do is install an FMU and you're done". I knew you'd left something out based on the previous discussions. I'd forgotten about boost referenced ignition modules, but knew that timing had to be addressed. Thanks for filling it in.
As too which is easier...that's ultimately a factor of which the builder is more comfortable and knowledgable.
Which for me both would be a learning experience. I've actually done more performance work on my Cummins (not that I've done much there either) than I have my 300. For that matter, I've done more performance related tweeking on gas turbines than recipricating.
Old Jan 2, 2008 | 08:56 PM
Silver Streak
I didn't really leave it out, I was just trying to focus on the differences between the two setups. Since either engine would need an upgraded ignition with retard control I left it out.
Old Jan 3, 2008 | 10:47 AM
John_deere_kid's Avatar
John_deere_kid
So which would be wiser to do? Carb or EFI?
Old Jan 3, 2008 | 11:47 AM
Silver Streak
For a weekend toy it could go either way. For something you need everyday I would go EFI because you don't have to do much tuning and once it's tuned you are done. With a carb you'll be jacking with it constantly.
Old Jan 5, 2008 | 07:24 PM
Grey89F250's Avatar
Grey89F250
SO I will need the mentioned ignition box and a boost controller and a turbo and some fab work? Hmm Junkyard here I come!
Old Jan 7, 2008 | 12:06 AM
justin_jkj's Avatar
justin_jkj
http://ca.youtube.com/watch?v=Kud-pj...eature=related
or just throw that into it...lol
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
