1978 - 1996 Big Bronco
Timing?
Old Jan 1, 2008 | 01:14 PM
GIXXED's Avatar
GIXXED
Timing?
Ok, Here is what I got..
1990 Bronco
302 5.0 Engine
Automatic
What is the trick to Timing the beast correctly. Computer likes to take over
Thank you in advance
Old Jan 1, 2008 | 01:32 PM
Red Ford Truck's Avatar
Red Ford Truck
Talking You must must must disconnect the Spout connector.
It's a little gray or black squarish plastic looking thing sticking out of the harness not too far from the distributor.
If you don't disconnect this spout you will never be able to set the timing because the advance is always present.
Warm up engine first then turn off and then pull the spout start engine again and proceed to time.
!!!!!!! Important!!!!!!!!! make sure you reinstall that spout after timing engine.
I hope that helps
Rick.
Old Jan 1, 2008 | 01:46 PM
GIXXED's Avatar
GIXXED
Thank you for the info. Have a great new year
Placermike
Washington Chapter
Jun 4, 2009 09:09 PM
jmms
Escape & Escape Hybrid
Aug 20, 2007 03:41 PM
lifted77f250
Apr 12, 2005 05:42 AM
390hiboy
Jul 26, 2001 10:32 PM
fordsrus
May 7, 2001 11:33 PM
