Offroad & 4x4
4x4 conversion
Old Dec 31, 2007 | 09:29 PM
evilbeast's Avatar
evilbeast
Exclamation 4x4 conversion
I am toying with the idea of converting my 87 f-250 to 4wd, and , there is only one thing that I am needing to know, is the front axle on these year/body style trucks a ttb, or solid axle, I have heard and seen differing opinions and examples. and if it isnt, where can i find a suitable cadidate for a solid axle swap or install? thanks all info is appreciated.
Old Dec 31, 2007 | 10:27 PM
teds74ford's Avatar
teds74ford
I would recommend a search as this has been covered many, many times.
Still, to answer, they are ttb. An F350 dana 60 is more or less a bolt in, though.
Old Jan 1, 2008 | 12:21 AM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Im assuming your truck has coils in the front? The 250/350 4wds had leafs in the front. Im not sure about how the frames vary fron coil to leaf in those years. Best bet for a solid axle is go with a 78-79 f-150 front axle with coils and swap in 8 lug outers. Then you can just use the factory 78/9 front radius arms.
Old Jan 3, 2008 | 07:09 PM
evilbeast's Avatar
evilbeast
but wouldnt the front end on the f-150s be a smaller ring and pinion, as well as have smaller axle shafts? id probably want to stick with the 250 or 350 front ends to keep the parts swapping to a minimum. the front end on mine does have coils, and swapping to leafs is definitely in the equation to make this right, as well as easier to get lift kits for it. so i am assuming that from the post prior to yours that getting all of the parts from a 350 would be the way to go for a solid axle if i would like to stick with the heavier axles?
Old Jan 3, 2008 | 07:22 PM
crazyredneckanyhow
Ok heres the deal as far as front end interchange. Both the 150s and 250s shared the Dana 44 front. The only difference is from the spindle out. Ring and pinion and the axles are the same. The only time this changes is if you have a Dana 60. I know this. Ive swapped outers before. The 8 lug spindle will bolt up directly to you 5 lug spindle. No fab work required. Coils in the front will give you more flex and a better ride. The front doesnt really do anything as far as carrying weight. As far as options you have more with coils then you do with leafs. You can get up to 12" lift coils and all the leafs ive saw only goes up to 6" unless you have something custom built. You shoudl run at least a 6" either way so the differential will clear the front crossmember on your frame.
Old Jan 5, 2008 | 01:56 PM
frdmike's Avatar
frdmike
they offered a dana 50 in the f-250, the 44 was the light duty axle.
Old Jan 5, 2008 | 02:04 PM
master_mechanic's Avatar
master_mechanic
If you want strength and good lift options stuck a leaf srung dana 60 in there thats what my trucks got and it works awesome
SVTDriver97
WTB - Parts & other
Feb 20, 2017 12:14 PM
DBD7
48
Jul 27, 2014 06:14 PM
Rusty36
29
May 4, 2012 08:14 AM
Powermonger
Sep 29, 2011 06:35 AM
brokeisnojoke
Jun 21, 2011 09:27 AM
