96 F150 solid axle swap
Old Apr 18, 2012 | 12:50 PM
Rusty36's Avatar
Rusty36
I have a 96 F150 4x4 with ifs and im looking into swapping to a solid axle. What year donor truck should I look for to have the sturdiest axle for off road use with little fabrication?
Old Apr 18, 2012 | 01:14 PM
rangergirl94's Avatar
rangergirl94
If your putting another d44 in it 78 & 79 f150 have the easiest axles to swap in
Old Apr 18, 2012 | 02:33 PM
khadma's Avatar
khadma
Carpenter Local 745
78-79 F150 or Bronco if using D44.
Also older units may be used, but make sure
It has disc brake set up.
There are companies making upgrades like:
Shock towers
Spring buckets
Extended radius arms
Springs
So, if you have a larger budget
You can get away by just finding a front axle housing.
Old Apr 18, 2012 | 04:39 PM
dmanlyr's Avatar
dmanlyr
Well if you are looking for the sturdiest axle(s), then junk the half ton stuff as step up to one ton axles.
Might take a bit more fab, but you can't beat the strength factor.
I also can't see any advantage to go SAS on half ton running gear as you really cannot safely run any bigger tires than you can with a properly setup TTB.
My opinion, David
Old Apr 18, 2012 | 07:25 PM
ROBZ95XJ's Avatar
ROBZ95XJ
either a Dana44 or Dana 60 require the same amount of work to swap in, like others have said a d44 isnt much of a upgrade of what you want, as far as d60's go, 78 and newer ford 60's are the best, 78-79 housing have alot of room on the drivers side for control arm mounts, later ones have less but can still work with ease, You can either buy a axle bracket kit or fab your own stuff, also around 92 they went from kingpin to balljoints
Old Apr 18, 2012 | 09:03 PM
SCRebel's Avatar
SCRebel
A D44 solid axle is a big upgrade. A D44 TTB, can only handle up to 35" tires on serious off-roading. A D44 solid axle can handle up to 39" tires serious off-roading. Yes, I know people that run 39" and even 40" tires with D44 solid axle, and abuse them.
Anything bigger than 40's I recommend a D60.
A D60 takes more work to swap than a D44, because you can use your TTB coil bucket/shock tower, and it gives you 2" more lift.
Old Apr 18, 2012 | 09:44 PM
ROBZ95XJ's Avatar
ROBZ95XJ
and thats why i see d44 stuff get constantly broken on lightwieght jeeps on 35-37" tires, i cant recomend anything bigger then a 35 unless you got high dollar axle shafts and ujoints, and explain why i d60 is more work, both axles need the same exact brackets and mounts, only diff is the bolt pattern
Old Apr 18, 2012 | 10:08 PM
GNR22's Avatar
GNR22
Gee I don't know. My D44 HD handles everything I throw at it. And it gets wheeled pretty hard with my 35"x15.5" swampers on it. Of course, the Dana 60 is stronger though. The nice thing is that the D44 is so cheap compared to the D60 which is usually around 1000 bucks. I would just find a D44 out of a half ton and throw it in, that way you still have the 5 bolt pattern front and back.
Old Apr 19, 2012 | 12:19 AM
rangergirl94
Anything in a jeep is gonna break lol even ford parts cant help a jeep
Old Apr 19, 2012 | 12:51 AM
Rusty36's Avatar
Rusty36
I would just find a D44 out of a half ton and throw it in, that way you still have the 5 bolt pattern front and back.[/quote]
How do i know the difference between the dana 44 and the dana 44 HD? Would the stock rear end in my 96 F150 hold up to the offroad or is there a rear end swap I should look into?
Old Apr 19, 2012 | 12:57 AM
Rusty36's Avatar
Rusty36
My opinion, David
I don't really wanna run any bigger than 35" tires. You think the ifs suspension with some aftermarket upgrades can handle the tires without changing axles while also not breaking? I want this truck to be solid something that i'm not gonna have to fix all the time.
Old Apr 19, 2012 | 07:51 AM
GNR22's Avatar
GNR22
The Dana 44 is 5 bolt, the Dana 44 HD is what they used in 3/4 tons so it's 8 bolt so it's easy to tell.
Old Apr 19, 2012 | 09:13 AM
SCRebel's Avatar
SCRebel
A D44 and D44 HD is exactly the same, except from the knuckles out.
If you have a D44 and want to go 8 lug in the future, you can get HD knuckles and a 10.25 rear axle and bam you got 8 lug.
Also a D44 high pinion solid axle was under the bronco from 78-79, and under the f150 from 77-79. I got mine from a 79 f150 for $150.
Old Apr 19, 2012 | 10:21 AM
GNR22's Avatar
GNR22
Internally yes. The HD will be set up for leaf springs and the Regular one will be set up for coil springs.
So you could have an 8 bolt front end with coil springs eventually if you wanted.
Old Apr 19, 2012 | 12:21 PM
andym's Avatar
andym
Dana 44, Dana 60, 35" tires, 40" tires... none of this stuff matters and no one can give you good advice without knowing:
- What size tires you plan on running
- What gears
- How much horsepower
- What you mean by "off road use". Rock crawling has much different requirements than a trail through the woods with an occasional mud puddle.
