cam,headers,intake,carb,bigger exhaust and you'll still have a lot leftover.700-800$ is a good chunk of change to take with you and your heads to a machine shop(roller rockers and other valvetrain improvements). GET RID OF ANY FRICTION POSSIBLE!
>POSSIBLE!
Cool, thanks, what do you think the range of hp increase is? Oh, and what kind of intake?
thanks a bunch
I'd spend $75 on the materials needed to exhaust port the heads and do that, $250 for a stock valve job, $50 for a gasket kit, $175 for a Comp cam and lifters, $75 for a new timing gear set ('68-71 to get rid of your current 4 degree retardation), $200 for a Performer RPM manifold, $275 for a rebuilt Performer 750 carb, $500 for L&L headers and the remainder for a good 3" exhaust and mufflers.
With your low compression engine, that should put you near 350-375hp and 400+ftlb of torque.
Holley 750DP, performer rpm intake,PORT AND POLISH THOSE HEADS!,I have always preferred crane over comp but you cant lose either way(basic rpms:1500-5000 or better),good timing chain,any decent headers will do(L&L,Hooker,Hedman),3" lines with high flow mufflers if street, and you will be running with the big dogs!
My mud machine runs a 547(4.5" stroke and 4.40" bore) Ford BB.Victor intake,victor heads,crane roller cam,powerforged 10:1 pistons,1250 Dominator carb,Hedman 2" primary zoomie headers,and a cloyes double roller chain.Never ran her in public yet but it blows through my 4 foot deep "TEST HOLE" with ease.
>with the big dogs!
>with ease.
What else have you done to the engine since your last post? if nothing, what is your plan for heads? Stock, or? They, with c/r, determine your cam. Everything added to the shortblock is there to support the cam.
