top 5
Old Nov 4, 2002 | 10:24 AM
erikl85's Avatar
erikl85
top 5
righto. And that would cost around 75 bucks?
Old Nov 4, 2002 | 11:26 AM
georgedavila's Avatar
georgedavila
top 5
If you do it yourself. Figure $300 to have it done. A porter will flow test them and provide you with those numbers. Other than stock flow numbers, until you know what ported heads will flow, choosing a cam is a shot in the datk.
Old Nov 4, 2002 | 06:49 PM
erikl85's Avatar
erikl85
top 5
Alright, let's assume i am running stock. What cam kit would you recommend?
Old Nov 4, 2002 | 07:46 PM
georgedavila
top 5
Stock heads flow an average of 135cfm on the exhaust port. That will support a maximum cam lift of .500-.520. Anything higher is wasted, as the exhaust port won't handle it. You'd be over-cammed. I'd recommend around that lift with a dual pattern of 210/218 degrees of duration @.050 to help the exhaust and 110-112 lobe separation angle. Any hydraulic lifter will do the job. You may have to buy a package of cam and lifters as there's a shortage of flat tappet lifters and many suppliers won't sell lifters as a separate item.
Old Nov 4, 2002 | 11:40 PM
erikl85's Avatar
erikl85
top 5
Cool, that is valuable info. Any specific cams?
thanks
Old Nov 4, 2002 | 11:44 PM
erikl85's Avatar
erikl85
top 5
how about these? Do i need multiple cams?
Vendor: Competition Cams
Product Line: Competition Cams High Energy Camshafts
Material: Cast Iron
Finish: Machined
Performance cams for the street.
Ford: 1968-94 429/460, 268/268 degrees duration, hydraulic, High Energy camshaft
This High Energy camshaft is designed for street engines. It will produce more power than a stock cam throughout the rpm range. High Energy camshafts work great for everyday driving. This cam will produce more power, is more efficient, and will not affect your engines idle characteristics.
Sold individually.
At Summit Racing Equipment, we do business based on a very simple idea. If you're not 100% satisfied with our products, prices, or service, we'll give you your money back--GUARANTEED! Just return any new or unused part to us within 90 days from the date it was shipped to you, and we'll refund the full purchase price. (Excludes custom-ordered parts.)
Competition Cams Inc. warrants that all of its products are free from defects in material and workmanship, and against excessive wear for a period of 12 months from the date of purchase and is only valid for the original purchaser. Camshafts will be covered by this warranty only when used with new lifters and the correct valve springs. Comp Cams' obligation under this warranty is limited to the repair or replacement of the product. There is absolutely no warranty on the following:
A) Any part used in a racing application
B) Any part that has been altered or improperly installed
C) Any part used in an improper application
This part fits the following applications:
Make Engine Year
FORD 429 1968 - 1973
FORD 460 1968 - 1994
Recommended parts:
* Lifters: CCA-832-16
* Valve Springs: CCA-940-16 (valve spring oil shield available)
* Retainers: CCA-743-16
* Valve locks: CCA-601-16
* Valve seals: CCA-502-16
* Factory springs can not be used
* Late model heads with fulcrum mount rockers can be converted to an adjustable valvetrain with studs and guides plates
* This camshaft is for carburetor equipped vehicles
Specifications:
* Advertised duration: 268 intake/268 exhaust
* Duration at .050 in. cam lift: 218 intake/218 exhaust
* Gross valve lift: .494 in. intake/.494 in. exhaust
* Lobe separation: 110 degrees
* RPM range: 1,500 to 5,500
Old Nov 5, 2002 | 08:24 AM
georgedavila
top 5
That'll work, but I'd use one that favors the exhaust by about 8 degrees of duration @ .050.
I don't understnd what you mean by multiple cams. You only need one camshaft.
Old Nov 5, 2002 | 09:03 AM
erikl85's Avatar
erikl85
top 5
Thanks, i realize that, but summit racing said that they were sold individuallly. So that threw me off, and i thought better be safe than sorry. I appreciate all your help
Old Nov 18, 2002 | 10:49 AM
erikl85's Avatar
erikl85
top 5
Would it be recommended to get a torque converter to support a higher idle? I see that alot of these cams have power ranges above 2000 rpm, and i do not know about this truck but i do not think that it is too high revving.
Old Nov 18, 2002 | 06:15 PM
erikl85's Avatar
erikl85
top 5
damn this forum is dead today...
Old Nov 18, 2002 | 08:19 PM
vancloud's Avatar
vancloud
top 5
Hi Erik #l85, Hows it going? About quote "You may have to buy a package of cam and lifters as there's a shortage of flat tappet lifters and many suppliers won't sell lifters as a separate item". With a new cam you should always use new lefters.
Old Nov 18, 2002 | 09:41 PM
skipper's Avatar
skipper
top 5
If you want to build your engine for horsepower I would say go with Edelbrock's complete Performer RPM package minus the heads. Get your stock heads ported and polished. You will also need an adjustable valvetrain(Edelbrock cam requires it), headers, an Edelbrock Performer 750cfm carb, and the timing chain for a '68-'71 460. If you look at Edelbrocks RPM cam it may seem like you will lose all of your low end but there is still quite a bit. I am using an Edelbrock RPM cam in my truck, which is my daily driver, and I think it is great. I would definately not use this cam if you plan on towing, but for daily driving and off roading it works great, or at least it does for me. You will, however, need to get a higher stall speed torque converter if you have an automatic.
Old Nov 18, 2002 | 11:04 PM
  #28
erikl85's Avatar
erikl85
top 5
Thanks! How much would an adjustable valve train cost me? I am down to around 700 bucks of budget after:
Edelbrock performer 750 cfm carb
Edelbrock performer rpm intake manifold
landl headers
dual flowmaster 30's
And i still need to port the heads, get a cam, get a timing chain, plus probably that torque converter. And truthfully, i do not really know what an adjustable valvetrain is.
Old Nov 18, 2002 | 11:40 PM
  #29
erikl85's Avatar
erikl85
top 5
How do i know what transmission i have?
Old Nov 18, 2002 | 11:51 PM
  #30
merc460's Avatar
merc460
top 5
your tranny should be a C6. Eric
