332 stroker
Old Dec 31, 2007 | 12:00 PM
332_58 f100's Avatar
332_58 f100
Smile 332 stroker
Ok guys i need a big question answered. I wanna build a 332 stroker motor. I know John murrmet sell a kit but i was wondering if it would be cheaper to buy the pieces myself? What parts does he use to get the stroke and bore? If i could get some specs id love to look into it.
THanks
Old Jan 2, 2008 | 07:37 PM
pcmenten's Avatar
pcmenten
Do you mean a Ford y-block stroker? As opposed to a FE 332 or a Lincoln y-block?
If and when I get the chance to build a y-block stroker, I'll use either a 312 with an offset grind on the rod mains, and use custom rods and pistons, or go with a custom grind on a 351 crank. There's a guy here in Boise with a special crank lathe that can do the offset grinds without drama.
The other part of this kind of build-up would be the bore of the block. I've heard of some ungodly overbores on y-blocks, and if you're going for cubic inches, I'd be thinking in terms of a bore of 3.86" from a 50's 292 or 312 block.
Rusty_S
Jan 16, 2016 05:06 PM
Dlasure2
Jun 11, 2013 06:32 AM
COE 53 M/H
Jan 14, 2012 11:47 AM
RobW
1983 - 2012 Ranger & B-Series
Sep 21, 2009 11:19 PM
roller_steve
Aug 2, 2008 11:35 PM
