Error Code 332: Insufficient EGR Flow Detected
Old Jul 27, 2008 | 01:25 PM
roller_steve's Avatar
roller_steve
Hello:
I have been getting this intermittent message from my computer system on my 1995 F-150, I-6 truck. It's a 4.9 liter 2WD. It says Error Code 332: Insufficient EGR Flow Detected.
Anyway, what is the least inexpensive way to get this thing repaired. Is there a particular valve that needs to be replaced?
Thanks for all your past help on this forum.
Steve
Old Jul 27, 2008 | 01:31 PM
danr1's Avatar
danr1
More to it then just changing a valve, you really need a service manual for it so you can follow the testing procedures in it and find the cause of the problem.
A number if things could cause that code, one to check for first is a vacuum leak in the system. Check every vacuum line on it, it should have no leaks. Lines get old and crack, get pinched and or melted and so on so look at them all.
Old Jul 27, 2008 | 01:34 PM
danr1's Avatar
danr1
Oh and the rigid plastic lines get very brittle, just moving one to look at or move it out of the way can make it crack or snap off. If you find them to be chaulky and brittle, break easy, replace them all.
Old Jul 27, 2008 | 02:11 PM
roller_steve
EGR Valve troubleshooting.
I think about a year ago, I checked the hoses for this intermittent EGR problem. The problem is, the part in question costs about 80 dollars, and I don't want to spend the money only to find out that's not the problem. Otherwise, I would buy it.
I have a Chilton manual for my truck, and all the instructions I've read say to do a tachometer test, which I don't have, as well as a vacuum test. I believe I did something like this before, minus the tachometer (which I don't think is necessary). The vacuum test was a matter of just putting my hand over the hose to see if it pulled a vacuum. It did. I am leaning toward replacing that expensive part.
Anyway, I am going to read this manual thoroughly and see where all this goes. I hope I get it right, but it's hard to say. I may just chance it and get a new EGR valve. If I fail at solving the problem, then it's just water under the bridge.
Overall, I get most of my repairs done, and I am glad this forum exists. I've saved hundreds, maybe even over a grand fixing my own truck.
Steve
Old Jul 27, 2008 | 06:13 PM
ryan f150 4x4's Avatar
ryan f150 4x4
check the vac can on the right innerfender thay rust out . It did on my truck i only had 5lbs of vac befor i got a new one now i got 18. the egr solanoid will not work with out vacume so dont asume its the solanoid it u test the vacume
goodluck hope this helps
Old Jul 27, 2008 | 08:53 PM
danr1's Avatar
danr1
With it idling put a hand vac on the egr valve vacuum nipple, draw vacuum on it. If the idle drops a hundred or more RPM's then the valve is working.
You can draw some vacuum on it with your face if you do not have a hand vac, not preferable but would work in a pinch.
There is two other parts that could be bad, don't just guess and replace the valve itself.
Egr valves are tough, if it was working and just quit its likely to be something else and not the valve. They freeze up when people do not fix the system and they remain closed for a long time.
Old Jul 28, 2008 | 03:52 PM
skaterbro's Avatar
skaterbro
Your use of the word "intermittent" leads me to believe that it would be a vacuum leak. As stated before, the plastic lines can become brittle and weak, eventually cracking or breaking.
It takes more time than money to replace the vacuum lines, so i'd start there. If it's all original, it probably needs replacing anyways.
Old Jul 28, 2008 | 05:16 PM
roller_steve
Regarding pressure tests:
Hello:
I found a site that has a link related to my Error 332 code. It said that I should remove the engine manifold and clean out the coke from the intake port where the EGR valve goes. Is removing the engine manifold hard? I pretty much can do anything I put my mind to. Basically, the author of the article states that there's usually not a problem with the EGR valve.
Check Engine Light with EGR Error Code :: SHOtimes FAQ :: Frequently Asked Questions (FAQ) about the Ford Taurus SHO from the SHOTIMES mailing list.
Let me know what you think of this article.
Steve
Old Jul 28, 2008 | 05:52 PM
skaterbro's Avatar
skaterbro
If it's that crudded up, it definitely needs to come off for cleaning. It's really nothing to take the plenum off either. And it's the only way to visually check the vacuum lines that run back there.
I'm still leaning towards a small vacuum leak though.
Old Jul 28, 2008 | 06:59 PM
danr1's Avatar
danr1
The code "Insufficient EGR Flow Detected" simply means the computer did not get a signal that the valve opened "moved". It does not in anyway measure the "flow" through the intake passages.
So either the valve opens and the sensor is bad or the sensor works and the valve did not move. You need to find out if the valve functions first, if the controls work. IE does the switch that opens the vacuum supply to it work, and does the sensor that senses it move do so when it moves.
You really need to start with the basics, follow the instructions for testing the components in the manual first step by step.
Tearing the motor apart is not the answer, it may come to that but I doubt it. That would only need done on a very high millage motor that had little to no maintenance done to it in it life, one that is a "oil pumper". If your motor fits that description, block the EGR openings with a steal plate and plug, you have bigger problems!
And yes double triple check for vacuum leaks, has to be the #1 cause of EGR trouble codes.
Old Jul 29, 2008 | 01:18 AM
Midnight88's Avatar
Midnight88
i got the same code on my truck awhile back, take the handle of your screwdrive or something to smack with. then smack the top and sides of your EGR a few times, usualy the little valve inside gets stuck, this will free it up *USUALY*. It fixed my trucks code! Its worth a try and its FREE!!!!
Old Aug 2, 2008 | 11:35 PM
e1p1's Avatar
e1p1
Originally Posted by roller_steve
Hello:
Steve
Hope you're still looking at this thread. What the author wrote could be true. My wife's 94 Lincoln TC had a similar issue, common to that era TC. In the 4.6 V8, the right side valve seals get brittle and dump oil into the cylinders, the resultant smoke over time clogs up the passage to the EGR manifold.
I cleaned that bugger twice in 4 years before finally breaking down and doing the seals too.
That said, check all the vac lines and other possible candidates before tearing iin. Can you spray some cleaner into a vac line near the EGR, to hopefully loosen the crud up, maybe tap with a hammer after spraying?
I'm unfamiliar with the 4.9...are you sure you must remove the manifold to get at the area in question? On the TC, I left the intake manifold alone and went after the EGR manifold, as I recall.
tfs2403
Feb 21, 2016 06:38 PM
truck crazy man
35
Feb 12, 2016 08:14 AM
TrueBlue02
Nov 16, 2015 05:07 PM
My Good 'ol 92
Aug 14, 2011 12:10 PM
cmccul002
1983 - 2012 Ranger & B-Series
Apr 13, 2008 06:59 AM
