Sponsored by: Real Truck
Cold White Smoke !
Old Dec 30, 2007 | 07:21 PM
schultz's Avatar
schultz
Question Cold White Smoke !
I HAVE A 03 F 250 WITH A 6.0 .It has 103.000 miles.I have started seeing a good bit of white smoke when it cranks on a cold morning after about 5 mins it goes away & the truck runs fine.Is this any reason for concern?
Old Dec 30, 2007 | 09:25 PM
oltrucker's Avatar
oltrucker
its probably unburnt fuel. incomplete combustion from low temps and some lose of compression. the sooner you drive off, the better it will be for the engine to get up to temp.
Old Dec 30, 2007 | 11:09 PM
94yj's Avatar
94yj
that sounds like warm exhaust meeting cold exh pipe making steam and it is normal if you look at it when it happens you can see right thru it many vehicles have done it for ages
Old Dec 31, 2007 | 01:10 AM
Izzy351's Avatar
Izzy351
Typical cold weather operation for a diesel. Worry about it when you have trouble starting and/or the white smoke gets a lot thicker. Typically, starting without glow plugs when cold will put out a nice white smoke screen.
Old Dec 31, 2007 | 01:16 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Yah its normal. My 04 X does it on the first start of the day
mmenzies
Nov 15, 2012 05:56 PM
linus72
Apr 16, 2012 07:40 AM
bebeard
Feb 8, 2012 11:58 AM
mxracer3276
16
Mar 5, 2009 08:35 PM
