White Smoke....
Old Feb 7, 2012 | 08:49 PM
bebeard's Avatar
bebeard
White Smoke....
hi all,
When my truck is cold, and hasn't been plugged in... I will have white smoke coming from under the hood and exhaust pipe.
What could this be?
Thanks,
Brook
Old Feb 7, 2012 | 09:27 PM
critterf1's Avatar
critterf1
Does it smell like fuel or coolant?
Old Feb 8, 2012 | 01:37 AM
bebeard's Avatar
bebeard
White Smoke....
I will check it in the morning.
I can't remember what the smell is like..
Brook
Old Feb 8, 2012 | 05:32 AM
npccpartsman's Avatar
npccpartsman
White smoke from under the hood is kind of strange. When you cleaned your EGR valve did you check for the presence of coolant in the intake? Parking the truck nose down overnight will allow you to see if you have any coolant in there (with the valve out).
Old Feb 8, 2012 | 06:40 AM
bebeard's Avatar
bebeard
White Smoke....
No I didn't check for coolant, but I have the perfect driveway to park it and check.
If that is the case, what would be the cause?
Brook
Old Feb 8, 2012 | 06:43 AM
critterf1's Avatar
critterf1
Ruptured EGR cooler.
Old Feb 8, 2012 | 10:28 AM
doug1967's Avatar
doug1967
Have a problem with white smoke also after about 15 or 20 min of running,smells more like fuel than coolant not sure. Dosent do all the time may go 3ot4days without anything. Idles good,slight hessiration at acceleration,all fluids fine and not throwing out any codes.
Old Feb 8, 2012 | 10:42 AM
doug1967's Avatar
doug1967
Has 110,000 miles
Old Feb 8, 2012 | 11:16 AM
critterf1's Avatar
critterf1
An injector with a mind all it's own.
Old Feb 8, 2012 | 11:58 AM
doug1967's Avatar
doug1967
Makes sence newer cooler and brand new egr valve altho already gunked up.
429poweredf350
Jun 20, 2014 11:13 PM
Pridnjoy
Oct 27, 2013 04:00 PM
elkohcaliente63
Mar 15, 2011 11:43 PM
joe doyle
Aug 21, 2010 01:03 PM
powerstroke219
Apr 19, 2008 08:34 PM
