Trans Fluid Spec
Old Dec 30, 2007 | 01:04 PM
itsmywifestruck's Avatar
itsmywifestruck
Trans Fluid Spec
Hey all...
I am puttin a tranny in a 98 Ranger. 3.0, 2wd. Does this truck require Mercon V, or can I run regular ATF? The owner's manual is gone from the truck, and Mercon V isn't stamped on the dipstick tube. I need to know pretty quick, so I can get this job done and gone...
ROb
Old Dec 30, 2007 | 02:23 PM
karageorge2's Avatar
karageorge2
on my 96 auto 2wd 4r44e it is mercon stamped on the dipstick. not sure on 98
Old Dec 30, 2007 | 03:25 PM
itsmywifestruck
just mercon or mercon v?
ROb
Old Dec 30, 2007 | 04:12 PM
karageorge2
actually mercon v supersedes and can be used in older mercons, i believe. correct me if i'm wrong. but if you read the label on the merc v it should tell you.
Old Dec 31, 2007 | 08:01 AM
scottpower's Avatar
scottpower
Don't mix Mercon and Mercon V. There are threads in the Explorer and/or Expy threads giving the Ford TSB and engineering studies stating they do not mix. Even a flush doesn't get all the old out. I forget the tranny #s for each but some trannies changed the fluid type effective with certain years. The stick is where to look but yours might not state which? I'd wait for a specific answer from someone with that specific year tranny. Not much help here but be sure what you need before adding I'd suggest..
Old Dec 31, 2007 | 08:22 AM
Rockledge's Avatar
Rockledge
Mercon V is now recommended by Ford in all trannies previously calling for regular Mercon.
https://www.ford-trucks.com/forums/6...lo-merc-v.html
Old Dec 31, 2007 | 06:30 PM
reddog99's Avatar
reddog99
ROb
Mercon is no longer made. As has been stated, Mercon V is the recommended replacement for all previous versions of Mercon.
Old Dec 31, 2007 | 07:13 PM
scottpower's Avatar
scottpower
Right you are.. I woner what Ford would say about the 2 plus year old TSB copy I have stating to service managers, do NOT mix them to include flushes? Guess they had a bunch of Mercon to get rid of??
Old Jan 1, 2008 | 08:29 PM
reddog99's Avatar
reddog99
Like today's "water saving" toilets, flush twice...
Old Jan 2, 2008 | 12:57 AM
R031Kona's Avatar
R031Kona
The aftermarket still makes and sells Dexron/Mercon , try Exxon. Yes , if you read a bottle of Dexron it says Dex/Mercon on it.
Old Jan 3, 2008 | 09:26 PM
itsmywifestruck
I finally got my head out of my butt and looked at the dipstick itself...it had Mercon V. The reason for my inquiry is that I didn't want to have to by that expensive stuff unless it was absolutely necessary. But I had too...but it is all together, and got the cash in pocket for the job...so it is all good
ROb
Escapeartists
Escape & Escape Hybrid
Jan 6, 2015 11:24 AM
whatstar1117
Aerostar
Nov 18, 2009 04:47 PM
60RatRod
Dec 6, 2008 06:15 PM
JFUSION
Nov 21, 2006 08:34 AM
chrison600
Apr 29, 2003 01:09 AM
