Dead Truck Need Help Please!!
Old Dec 28, 2007 | 08:22 PM
ech0sh4y's Avatar
ech0sh4y
Cool Dead Truck Need Help Please!!
I have a 95 f150 (in sig)... I was driving home tonight and it just like died no sputtering no anything just lost power and died... i thought no gas.. which i was low then i got it started after 20 mins... drove to a gas station and filled it up... then on my way home again it died same as before, this time no start... i got towed home. So far this is what i know:
- runs on ether (starting fluid)
- Fuel pump isn't kicking on
- all fuses are good for fuel and relay also the emergency shut off wasn't tripped
Please help?! Bad fuel pump? Frozen fuel? Truck has 136,000 miles on it!
Old Dec 28, 2007 | 08:28 PM
95F350XL's Avatar
95F350XL
If you have dual fuel tanks, then the switch could be acting up, I know where is something that is there if you only have 1 tank. Your pump could be crapping out.
Old Dec 28, 2007 | 08:31 PM
ech0sh4y's Avatar
ech0sh4y
it's a shorty box with 1 tank.. any way to test fuel pump? what is the swtich thing?
Old Dec 28, 2007 | 08:35 PM
rustee90-150's Avatar
rustee90-150
when u turn on the ignition can u hear the pump startup ? if so is it louder then normal ?. my truck did roughly the same thing replaced the pump its pritty easy to do. but it sounds to me like a bad pump
lostin90s's Avatar
lostin90s
Switch is for the dual tank trucks. Check for power at back harness plug . when turn key on. Can you hear pump at all?
95F350XL's Avatar
95F350XL
The dual tank trucks have the switch for front and back. Since the 1 tank truck dont have it, there is something that is plugged into were the switch would be. If you run your truck and let it die, then using a dead blow hammer bang on the bottom of the tank, while someone tries to start it. If it turns on ur pump is bad. You can also throw on a fuel pressure guage, watch the guage and if the pressure starts dropping and then the truck stalls see where the pressure stops at, then try to restart and see if the pressure is there. If no pressure its the pump.
Old Dec 28, 2007 | 08:40 PM
ech0sh4y's Avatar
ech0sh4y
the truck won't run with out either... no fuel pump isn't kicking on when i turn the key to run... where is the harnes to check for power?
do you hit the middle of the tank? Can i just leave the key in run and hit it to hear if the pump kicks on?
Thanks guys!
Old Dec 28, 2007 | 08:44 PM
rustee90-150
ya u can leave the key on and jently kick the center of the tank .
does it have the side tank or rear tank?
Old Dec 28, 2007 | 08:45 PM
ech0sh4y's Avatar
ech0sh4y
It has the rear tank
Old Dec 28, 2007 | 08:46 PM
95F350XL's Avatar
95F350XL
That will work also. The harness runs along the frame and then crosses over 2 the tank. If you look around the tank you will see the harness going 2 it.
Old Dec 28, 2007 | 08:49 PM
rustee90-150
ok the harness comes in on the front side of the tank in the center if u can see the plug pull it off and clean the terminals and bend the little sockets in a little on the plug so they fit tighter i dint think u have to lower the tankto get at the plug.
Old Dec 28, 2007 | 08:52 PM
ech0sh4y's Avatar
ech0sh4y
ok standby i'll go try it! thanks again guys i really appreciate you speedy responses!
Old Dec 28, 2007 | 09:12 PM
ech0sh4y's Avatar
ech0sh4y
ok well i found the plug i think, it has 4 wires... i have power on one of them on both sides of the plug with the key on run.. is this right?
Hitting the tank didn't do anything
Old Dec 28, 2007 | 09:17 PM
95F350XL's Avatar
95F350XL
I think one should be 12V hot, and 1 should be a signal to turn the pump on.
Old Dec 28, 2007 | 09:18 PM
rustee90-150
not too sure howmany wires are supposed to have power back there but if u claened the connection s up and put it backtogether and it still dosent work i would say its a bad pump.
