Degas bottle running over
Old Dec 26, 2007 | 11:02 PM
Izzy351's Avatar
Izzy351
Originally Posted by jamesdellinger
Bought the pump at Advance and the Thermastat at the ford place and it is the short one. ///SNIP///
Our PSDs require the long one. If you indeed have the short one, that's likely your problem.
Old Dec 27, 2007 | 06:24 AM
jamesdellinger's Avatar
jamesdellinger
Advance has never heard of the PSD's taking the long t-stat and Keeter Ford sold me a short one too. Seems to me they should have known which one it took.Maybe looking to cash in on some repair work? Advance couldn't even cross reference it to come up with a long stem t-stat. All their books and computer show is the short one. I took the short one with me and had them to get a new waterpump off the shelf,stuck the t-stat in and showed them how far away it was from the pump bypass.
NAPA ask " well why does it need to be that long " ? They also sell the short one.
I will be taking the pump off this afternoon and I'll let everyone know what I find out.
I'm getting kind of worried about it.If it has caused major problems I think Advance & Ford should pay to have my truck fixed. I have grown a little angry over the past month trying to figure out why this was happening,I just hope there is no damage to my truck.
Old Dec 27, 2007 | 06:36 AM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
well you might have cause a damage, i read somwhere that the short t-stat, will cause partial circulation, cauing rear of the block not to get the proper cooling and overheating it, and you gauge wont show it at all.
i think those idiots dont know what they are talking about. you need long steam t-stat, and take it apart ASAP. dont drive it like that, i hope your motor is ok.
Old Dec 27, 2007 | 07:56 AM
Izzy351's Avatar
Izzy351
Yep -- the coolant back there sits & cooks while what little comes out past the 'stat & sensor are cool as can be. Not good -- I'm prayin' for ya' though!!
Old Dec 27, 2007 | 08:17 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
No one has asked the obvious question as far as I saw. The old thermostat, long, or short?
Old Dec 27, 2007 | 08:19 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If you can't find the long shaft, here is where lots of us get ours. http://www.dieselsite.com/index.asp?...S&Category=203
Good luck.
Old Dec 27, 2007 | 09:35 AM
Kwikkordead's Avatar
Kwikkordead
It builds as soon as I start it. The water will slowly start to rise and then blow out from under the cap. My temp always shows normal.
This is a bad sign. Especially if the engine is still cold to the touch and it's building pressure.
Head gasket.
Old Dec 27, 2007 | 12:47 PM
zx250's Avatar
zx250
Of the next Riffraff East
Head gasket.
It is starting to look that way. He hasn't stated it the pressure build up started right after his repairs, or if he drove it around for a while then noticed it. If that is indeed his problem, did the short t-stat cause it?
Old Dec 27, 2007 | 01:11 PM
jamesdellinger
Well I took off the waterpump. Is it possible that the fan on back of the pump is backwards ? The fan is reverse rotation and the fan will just be slapping water. Seems to me like it should be the other way to pump water, like digging into the water. Dont seem to be any signs of fuel in the coolant,No smell either.
The old T-stat as far as I recall was also short,but I didn't look at the pump depth before I tossed it. This one is 2 1/8 deep and the short T-stat will not reach it.
Old Dec 27, 2007 | 01:25 PM
miller_feed
Would it be possible for the belt to be on the wrong side? This might be way off, but what the heck.
Old Dec 27, 2007 | 01:34 PM
jamesdellinger
The rotation on the fan is counter clock wise.The engine turns clock wise there fore the belt crosses the top of the pully to make it turn counter clock wise.
Old Dec 27, 2007 | 01:36 PM
zx250's Avatar
zx250
This is the only picture I could find. Does your impellers look like this?
Here is you belt directions as well.
Old Dec 27, 2007 | 01:53 PM
  #28
jamesdellinger
Yes everything looks just like that. What do I do now ? Put it in the shop ?
Old Dec 27, 2007 | 01:57 PM
  #29
zx250's Avatar
zx250
Man, other than pray, I don't know for sure. How much running time did you put on it since the repairs?
Old Dec 27, 2007 | 01:59 PM
  #30
zx250's Avatar
zx250
Just noticed in your profile that you are here in NC. Where at? Close to Concord?
