Degas bottle running over
Old Dec 26, 2007 | 11:18 AM
jamesdellinger's Avatar
jamesdellinger
I recently replaced my waterpump and thermastat and now if I start my truck and let it sit and idle it will build pressure and blow my collant out from under the cap.What will cause this ? I have been reading the forum and find that there is two thermostats for this model truck, could it possibly be this or am I looking at a blown head gasket ?
2001 7.3L powerstroke
no water in the oil and none coming out the exaust.
What to do?
Old Dec 26, 2007 | 12:15 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Well i have to say at idle, it probably is a headgasket going bad. Thats a slow RPM to have that much gasses in the system. It could be a very severely cracked injector cup and broken copper o-ring on the tip of the injector body, but even that would cause a situation with alot of fuel in the coolant, and coolant in the fuel (white smoke).
Old Dec 26, 2007 | 12:36 PM
zx250's Avatar
zx250
Of the next Riffraff East
Could a bad t-stat or one in backwards prevent the coolant circulating and pump building pressure? Just a guess since problem wasn't there before new parts.
Old Dec 26, 2007 | 12:50 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You did put in a long shaft stat? Not sure what the short one will so.
Old Dec 26, 2007 | 02:00 PM
jamesdellinger
Bought the pump at Advance and the Thermastat at the ford place and it is the short one. Its 1 3/4" long and from top to bottom the pump measures 2 1/8".
I do have a little white smoke but after the engine warms, no smoke.I think bad glow plugs. Worse on cold mornings until warm then no smoke.
Old Dec 26, 2007 | 02:09 PM
zx250's Avatar
zx250
Does the pressure build after engine warms and does the engine temp rise above normal?
Old Dec 26, 2007 | 02:16 PM
jamesdellinger
It builds as soon as I start it. The water will slowly start to rise and then blow out from under the cap. My temp always shows normal.
Old Dec 26, 2007 | 02:27 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
if you didnt have that problem before , id say its somthing fishy about the t-stat, and or waterpump. did you srain the whole system? but it sounds like you have wrong t-stat or like zx250 said its reversed, and wont open against the preassure of the pump, blowing the coolant through the overflow tank.
Old Dec 26, 2007 | 02:39 PM
zx250's Avatar
zx250
Since you can't put a pump on backwards and the engine is not running backwards, something is blocking the flow, if its not the t-stat, then you need to find that rag you left somewhere. I'm gonna go with a bad or upside down t-stat.
Old Dec 26, 2007 | 02:40 PM
jamesdellinger
I will be tearing it back apart tommorow and going to the ford place to see if I can get the right parts. T-stat is not in upside down.I can only pray its not to serious.
Old Dec 26, 2007 | 02:45 PM
PETE'S_6.0PSD
well if you didnt drive it and didnt overheat the motor than you will be fine, just take it apart and check the t-stat, sounds like its stuck in closed position. and make sure its long housing one.
good luck and let us know your findings.
Old Dec 26, 2007 | 02:49 PM
jamesdellinger
We'll do........
Old Dec 26, 2007 | 02:51 PM
zx250's Avatar
zx250
What don't make sense is the t-stat remains closed until it warms enough to open, right? His is backing up into the overflow before it gets warm.
Old Dec 26, 2007 | 03:00 PM
PETE'S_6.0PSD
thinking about it, it don't make sense. so it might be a lot of air traped in, causing the gases to back the fluid up?
i would try to disconnec the upper radiator hose off and make sure its full (hose and radiator), before you put it back on.
otherwise it might be a big problem.
Old Dec 26, 2007 | 03:07 PM
zx250's Avatar
zx250
A lot of air could cause the problem, but shoud correct itself fairly quick. I can't imagine anyway the rad. hose could have gotten crossed, maybe the heater hoses? Just grabbing for straws now.
