Code Help
Old Dec 26, 2007 | 01:32 PM
Engine's Avatar
Engine
I purchased the EEC from RockAuto. I'll send an email to them and see what they think.
Old Dec 26, 2007 | 02:25 PM
codyingersoll123's Avatar
codyingersoll123
ok so I should clean up the body ground? Ill try that...but Im pretty sure its my eec. Like I said I replaced everything else on the dang thing. Is it the little black box up under the drivers side of the dash/kickpanel??? How much are they and who's rockauto??? Are they anygood? and are they cheap??
Old Dec 26, 2007 | 02:43 PM
subford's Avatar
subford
http://www.rockauto.com/
I get mine from a salvage yard for $50.00
Old Dec 26, 2007 | 02:52 PM
codyingersoll123
i went onto rockauto.com and couldnt find them is that something special that I need to call them about?
Old Dec 26, 2007 | 02:53 PM
Engine's Avatar
Engine
Unfortunately the local salvage yards did not have a EEC when I needed one. I paid $88.00.
Old Dec 26, 2007 | 02:57 PM
codyingersoll123
u paid $88 on rockauto???
Old Dec 26, 2007 | 03:01 PM
subford's Avatar
subford
They are on there but somehow I could not link to the page and post a link to it after I found them.
It looks like you will have to have your part number off the old one.
Old Dec 26, 2007 | 03:09 PM
Engine's Avatar
Engine
It was $88.00 after the core return.
Subford is correct, you will need the part number to be sure to get the right one.
Old Dec 26, 2007 | 03:59 PM
EPNCSU2006's Avatar
EPNCSU2006
I still am trying to figure out how it seperates a 3 digit code from a 2 digit code.
The digit separation is the same for both two and three digit codes. If you'll notice, the delay time between digits of a single code is shorter than the delay time between the last digit of one code and the first digit of the next. Once you stare at the check engine light blink a few times, you will get a feel for the delay time and you will recognize when a new code is starting and when it's just the next digit of the current code. That link I posted earlier should help you out with the timings.
Old Dec 27, 2007 | 07:36 AM
codyingersoll123
ok I found them on Rockauto...where are they in the truck?? Under the hood or in the cab under the dash???
Old Dec 27, 2007 | 08:37 AM
subford's Avatar
subford
Driver’s side kick panel. You get to it from under the hood but you have to loosen the inter fender to get it out.
Old Dec 27, 2007 | 11:13 AM
Engine's Avatar
Engine
I emailed customer service at RockAuto and these guys are great. They contacted the manufacturer of the EEC and found out that my symptoms could be from a bad unit. They preferred that I try another code reader before sending it back, but they will replace it free of charge.
I'm am now a big fan of RockAuto.
Old Dec 27, 2007 | 11:22 AM
  #28
codyingersoll123
Ok...im not sure I understand...its in the drivers side kick panel (meaning in the cab)...but you have to get to it under the hood??? Loosen the INNER fender???
Old Dec 27, 2007 | 11:59 AM
  #29
subford's Avatar
subford
Yes that is all true.
What do you not understand?
Old Dec 27, 2007 | 12:07 PM
  #30
codyingersoll123
well the whole in the cab and under the hood sounds kind of contradicting? Is it in the cab behind the plastic drivers side kick panel or is it under the hood near the icm or something?
