Thermostat
Old Sep 12, 2000 | 02:10 PM
fordsrus's Avatar
fordsrus
Thermostat
What is the difference between a 180 and a 195 degree thermostat. I live in Northern Kentucky, the temp. is as cold as 20 degrees in the winter to 95 degrees in the summer. Will it hurt the engine performance if I put the 180 or 195.
89 ford f-150
4.9L 300 inline
Old Sep 12, 2000 | 02:40 PM
hotrodford_88's Avatar
hotrodford_88
Thermostat
I think you have to go with the stock temperature thermostat. Due to the higher temperature messing with the calibrations of the computer.
The parts supplier should be able to tell you what the stock temp. is, I'm not really sure even though my truck used to have a 300 I-6 in it.
Hope this helps
Old Sep 12, 2000 | 11:22 PM
PAUL_2's Avatar
PAUL_2
Thermostat
Yes , If you go to a lower temp thermostat , the ECT Sensor sends that info to the computer & the computer will adjust the mixture accordinly , causing the engine to run a little richer than it should be running . Is your engine running hot ? I noticed Ford has a new design on their thermostats , it keeps the engine temp more constant than previous thermostats .. Ford Part No. XL2Z 8575 AB.
Old Sep 13, 2000 | 02:38 PM
fordsrus's Avatar
fordsrus
Thermostat
Thanks for the info. The reason that i asked because the temp. gauge nevers goes pass the N on NORMAL but the past week it's been going up to the R then quickly drops back down to the N. Then it will stay their. Until the next day when the engine cools it will do it again. And I didn't know if it was sticking or not. I'm going to replace it but did not know what degree thermostat it was.
Old Sep 13, 2000 | 05:56 PM
hotrodford_88
Thermostat
The temperature setting of your thermostat should be stamped into the button on the back side away from the point. Like I said it should be stamped on the back, if not it should be stamped somewhere on it.
Good luck, I know my truck never even hits the N
on the temperature scale. But I'm also running a bottle of "water wetter" from redline synthetic in the cooling system too.
1988 F-150 Custom to XLT Lariat conversion, 5.0 EFI (formerly 300 I6), 5-speed M5OD, 3.08 rear gears (will be upgraded to 3.55's), Summit headers, Flowmaster muffler W/ dual 3.5" tips 24" long.
Pioneer CD, AC, Tilt, Cruise, Mobile Radio, Lightbar (Force 4 LP6000), Federal Signal PA300 Siren W/100W Siren Speaker. Caution Customizing in progress, Watch for flying tools & Parts!
Old Sep 13, 2000 | 11:21 PM
PAUL_2's Avatar
PAUL_2
Thermostat
Id say if you noticed the gauge going higher than it previously had on initial warm up this indicates the thermostat is taking longer to open . Given the cost & ease of replacement its cheap insurance to replace it with a new one .
Old Sep 14, 2000 | 11:19 PM
PAUL_2's Avatar
PAUL_2
Thermostat
Macs1964F100
Nov 9, 2013 06:54 PM
Saxon
Dec 21, 2009 05:09 PM
Steve
Apr 4, 2006 11:46 PM
BigMacZack
Jan 19, 2004 01:11 PM
jcm
Jan 3, 2003 09:03 AM
