Sponsored by: Auxito
wheel bolt pattern
Old Dec 25, 2007 | 03:29 PM
aperez28's Avatar
aperez28
wheel bolt pattern
i have a 2002 f-150 with a 4.2L and my question is the following: will i be able to change my truck to a smaller bolt pattern so i can fit 20" wheels that were installed in a ranger? any comments or suggestions will be greatly appreciated. thanks in advance!
Old Dec 25, 2007 | 04:09 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
No. However, you might be able to find an adapter
Old Dec 25, 2007 | 08:25 PM
LxMan1's Avatar
LxMan1
No, you need 5x135mm bolt pattern wheels. I wouldn't recommend adapters on a 5000lb truck.
Old Dec 26, 2007 | 05:10 PM
steve(ill)'s Avatar
steve(ill)
the explorer bolt circle is 4.5 inch. the older (prior to 97) F150 is 5.5 inch, the new F150 are 135 mm. (5 bolt till aabout 2004, then 6 bolt pattern, same diameter) nothing interchanges-- dont use the adaptors.
Old Dec 27, 2007 | 07:03 AM
aperez28's Avatar
aperez28
thanks everybody. i guess i will have to find a buyer for the wheels and buy some new ones.
wildstang
Oct 30, 2011 06:23 PM
50adrod
Feb 9, 2011 05:48 PM
68shortbedmo
Dec 28, 2009 03:28 AM
Shanemh
Jan 15, 2007 09:22 PM
slow_v6_stang
Feb 1, 2006 07:40 PM
