Sponsored by: Auxito
fan problem
Old Dec 27, 2007 | 09:32 AM
BadAssFord's Avatar
BadAssFord
fan problem
i have a bent fan blade on my 98 f-150 and i was wondering how bad it would mess it up if i left it on or should i remove the entire fan and if so how do i remove it it has a clutch and spins when i try to loosen it.......thanks
Old Dec 27, 2007 | 12:12 PM
galaxie641's Avatar
galaxie641
If it is bent very much it could throw the whole assembly out of balance and would ruin the water pump eventually. You have to either rent/buy a fan clutch removal kit. They have a big wrench that fits over the pulley bolts and keep it from spinning while you use another wrench to pull the fan and clutch off. It would be a good time to install some electric fans since the old manual fan would be coming off.
