Ease My Mind!
Old Dec 25, 2007 | 02:25 PM
fordtruckowner's Avatar
fordtruckowner
Question Ease My Mind!
Saw something disturbing from my truck about an hour ago! I cranked my truck this afternoon and backed it about ten yards and then pulled forward into garage. (everything normal) I tinkered with truck for about two hours (non-mechanical or engine related) Cranked 2nd time to back out of garage. Looked in rear view mirror only to see large flume of blue grey smoke. It only lasted a few seconds and cleared. Truck is an 06 5.4 Screw with 14,000 miles and four oil changes to this point. What did I just see??????????? Is there a need for concern?????????
Thanks in advance.
Old Dec 25, 2007 | 02:38 PM
VFR_Man's Avatar
VFR_Man
Just sounds like a rich "poof" from having run it for only a short time and shutting it down. I wouldn't worry unless it regularly does it after shutting down a fully warmed engine.
Old Dec 25, 2007 | 05:45 PM
fordtruckowner
VFR,
That is what I was hoping to hear. Can you explain in laymen's terms kind of what occurs to create this rich condition and what actually creates the smoke. When I think smoke, I think two cycle where you run a fuel and oil mixture and you can create a rich or lean condition based on how much oil is mixed with the fuel. Obviously, with our trucks the oil and the fuel never mix. Just wondering. Thanks again for your quick reply.
Old Dec 26, 2007 | 12:01 AM
Jaynen's Avatar
Jaynen
Something similar to when you have to use the choke on a motorcycle to start it when cold. more fuel is necessary. If you shut it down while its in the middle of that its probably just some extra fuel left in the system that didnt make its way out
Old Dec 26, 2007 | 12:32 AM
DOHCmarauder's Avatar
DOHCmarauder
There is an issue with leaky injectors.....Ford took the high road and extended the warranty to 11/110 (?).
There have been cases where enough fuek leaked causing a bent rod due to hydrolocking.
That "extra fuel" may or may not have been the injector but it wouldn't hurt to have it checked out.
Old Dec 26, 2007 | 04:53 AM
svt2205's Avatar
svt2205
You've got nothing to worry about. It's not unusual from these motors. I'd only worry if it happens alot.
Old Dec 26, 2007 | 04:56 AM
greythorn3's Avatar
greythorn3
ya them are some leaky injectors i bet.. ive seen a few with bad injectors doing this.
ray
Old Dec 26, 2007 | 05:06 AM
greythorn3's Avatar
greythorn3
double post sorry
bergy 2000
Modular V10 (6.8l)
13
May 16, 2023 02:49 PM
AJB201
Jan 8, 2014 10:52 PM
bergy 2000
Apr 25, 2012 05:59 PM
bergy 2000
Apr 10, 2012 06:00 PM
Diesel_Brad
Nov 27, 2011 01:03 PM
