Heater fan
Old Dec 25, 2007 | 01:38 PM
Medic911's Avatar
Medic911
Heater fan
04 F150 FX4
My heater fan only works on 3 and 4 now. I did a search and found some reference to a "fan resistor pack"
Anyone know where this is located???
Any other ideas?
Thx
Old Dec 25, 2007 | 01:47 PM
REDFORDFX4's Avatar
REDFORDFX4
Originally Posted by Medic911
04 F150 FX4
Any other ideas?
Thx
Mine does the same thing 1 and 2 are low like 1 and then 3 and 4 are normal?
Any help for non expensive fix would be good!
Old Dec 25, 2007 | 01:51 PM
mattd17's Avatar
mattd17
you know, i have seen this before on a ford car, but the problem was within the switch, and not the fan itself..... just a quick thought to check.
Old Dec 25, 2007 | 02:35 PM
VFR_Man's Avatar
VFR_Man
Assuming the '04's are the same as my '07 diagram, the blower motor resistor is located on the right hand A pillar and has four wires in the connector.
Not knowing the history on these trucks, I would be inclined to suspect the switch too, like mattd17 said. That doesn't look like a cheap part either if it's the same as the '07 diagram.
Old Dec 29, 2007 | 07:07 PM
Medic911's Avatar
Medic911
Just to follow-up
Thanks for all the good info.
It was INDEED the blower motor resistor...located inside the vehicle near the "a" post...right near the blower motor and accessed by removing the glove compartment.
Took about 15 min. (actually took me longer to clean out my glove compartment) 1 plug, 2 screws.
$7.06 including tax.
Old Dec 29, 2007 | 07:33 PM
mattd17's Avatar
mattd17
good to hear you got it fixed.... and for cheap. its good for others to take note for future reference. thanks !!!
Old Dec 30, 2007 | 11:37 AM
REDFORDFX4's Avatar
REDFORDFX4
Just to follow-up
Where did you purchase the motor resistor?
Thanks!
Old Dec 30, 2007 | 01:28 PM
Medic911's Avatar
Medic911
REDFORDFX4
Purchased from local Ford dealer.
Old Jan 8, 2008 | 04:20 PM
REDFORDFX4's Avatar
REDFORDFX4
Smile
REDFORDFX4
Fan works great now with new resistor.
Thanks for the info.
ckutter
Mar 23, 2014 10:02 AM
rick90yj
Sep 30, 2012 07:07 PM
F-250 restorer
Dec 22, 2010 11:39 AM
Jeff Pugh
Jan 8, 2004 05:22 PM
Dualiedo
Sep 24, 2002 12:20 PM
