stalling
Old Sep 24, 2000 | 10:16 AM
pgood52636's Avatar
pgood52636
stalling
My son's 89 F150 with 4.9 starts then runs for a while then shuts down. The fuel pump quits running. Inline pump replaced and it ran for a longer period before shutdown. Starts up when the pump will come back on. Any Idfeas? Please email me : pgood52636(No Email Addresses In Posts!) or give any hints here.
Thanks Paul Goodman
Old Sep 24, 2000 | 12:49 PM
PAUL_2's Avatar
PAUL_2
stalling
Check the fuel pump relay & its wiring . Its located in the left engine bay , mounted in a long black block next to the air cleaner .
Old Sep 24, 2000 | 04:37 PM
fordmaniac21's Avatar
fordmaniac21
stalling
[font size="1" color="#FF0000"]LAST EDITED ON 24-Sep-00 AT 05:39 PM (EST)[/font][p]i am the son and it is my truck. i just replaced the relay about a month ago. and the wiring checks good. i hav just started replacing sensors. i am lost. if any info e-mail me fordmaniac21(No Email Addresses In Posts!) thanks
Old Sep 24, 2000 | 11:15 PM
PAUL_2's Avatar
PAUL_2
stalling
Emailing kind of defeats the purpose of the message board . Someone else may have a similar problem that could benefit from the post w/o actually having to go over redundant symptoms . Throwing parts at it & guessing is only a waste of your time & money . When the engine quits first check for spark & then the fuel pressure . Depending on what is not working will narrow down your search for the actual cause of the problem .
Old Sep 25, 2000 | 08:51 PM
pgood52636's Avatar
pgood52636
stalling
it's got spark but no power at the fuel pump until it sits for a while
Old Sep 28, 2000 | 01:57 PM
moley's Avatar
moley
stalling
By now power at the pump you mean you put a voltmeter on it and it goes to zero? If you turn off the ignition switch and turn it back on does power return? To my knowlege there isn't any sensor which would actually turn off power to the fuel pump.
When this happens, is there voltage to the red wire on the fuel pump relay? If so, then you've probably just found the problem.
I would seriously check the wiring to that relay. The contacts on that connector are made of crap and can corrode easily (like mine did). give each wire a firm tug and twist and see if one breaks loose. I bought a new connector (and just to be safe, another relay) at my local Ford dealership (Tasca) for 12 bucks.
Moley
89 F150 4x4 4.9L I6
Rehoboth, MA
Old Sep 28, 2000 | 07:44 PM
warthog299's Avatar
warthog299
stalling
1988F250
Jul 11, 2015 08:26 AM
mickey143
1997 - 2003 F150
Dec 10, 2011 12:24 PM
rkdickie
May 19, 2004 12:01 AM
Barrington521
Sep 9, 2003 10:52 PM
thefireman4652
Aug 4, 2003 11:09 AM
