Cck?
Old Dec 24, 2007 | 11:52 AM
jsmahan's Avatar
jsmahan
Cck?
Alright, I've been researching this for a while and cannot find who carries this kit. Any suggestions?
Old Dec 24, 2007 | 12:20 PM
Izzy351's Avatar
Izzy351
Here you go:
http://www.dinofuelalternatives.com/products.php?cat=56
Great product!! I highly recommend it, and DFA. They take great care of their customers.
Old Dec 24, 2007 | 02:17 PM
rebelchevy02's Avatar
rebelchevy02
X2, I have their kit aswell. Pretty nice piece.
Old Dec 24, 2007 | 02:32 PM
aklim's Avatar
aklim
Is there some reason you are going with that kit as opposed to the ITP or DI regulated return where you have a pressure gauge and regulator so you can control the fuel flow? If ever you decided to go that route, you would be wasting the money on this kit. So, IMO, if I wanted to do it, I might as well spend the money and do it right the first time. Every time I have skimped on the good stuff for the cheaper stuff, I end up kicking myself in the *** later on.
Old Dec 24, 2007 | 02:40 PM
Rich in CO's Avatar
Rich in CO
I went with the CCK over the RR kit the CCK is pretty much does the same thing as the RR kit, at the time only ran me $130.00 VS some thing like $500.00. As for fuel pressure I could not see spending the extra $100.00+ dollars for a regulator. I shimed the regulator to 70 PSI, and done, from reading on FTE most guy's with a regulator set it @ 70 and never make any changes, so I could never understand why I would want the extra regulator.
Old Dec 24, 2007 | 03:10 PM
JustinSWeber's Avatar
JustinSWeber
Do you remove the stock regulator when installing a RR kit or do you have to shim the stock regulator and adjust the new regulator as well?
Thanx for the info, looking at all options.
Justin
Old Dec 24, 2007 | 03:14 PM
JustinSWeber
Even to shim the stock regulator correctly we would need to install a fuel presure gauge and then shim per reading?
Old Dec 24, 2007 | 03:23 PM
JustinSWeber
Old Dec 24, 2007 | 04:29 PM
Izzy351's Avatar
Izzy351
Most won't need the full RR kit. I'm extremely happy with the CCK. I do hope to add the DFA full kit at some point. I do plan on adding a fuel pressure gauge like Brandon did, which you can do for ~$20:
http://cgi.ebay.com/ebaymotors/100-p...QQcmdZViewItem
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
