Fuel ?
Old Dec 25, 2007 | 08:33 AM
BIG R's Avatar
BIG R
Originally Posted by Dave Sponaugle
The internal vent hose is sorta easy to remove.
Best done when there is less than a full tank of fuel.
Remove the filler cap.
Remove the diesel only plastic label around the fill spout.
Now you should be able to see several screws that mount the fill spout to the body, remove them.
Stuff a rag in the fill spout to keep dirt out.
Next slide under the truck bed.
Now loosen the clamp on the filler hose to fill spout connection.
Slide a small straight bit screwdriver under the hose to break it loose from the fill spout, be careful not to tear the hose.
When you get it loose, remove the fill spout.
The fill spout flange is inside the bed, so to remove it you need to bend the hose and pull the spout under the truck to remove it from the hose.
Again, watch you don't get dirt into the hose.
The vent hose should be clipped to the fill spout.
Pull the vent hose out of the fill hose, file 13 the vent hose.
Now put everything back together like it was.
Go fill the tank, check for leaks.
This does not get rid of all the foam problems, but it does cut down on them.
It also lets more fuel run down the filler hose, so fill time is reduced.
I sill like to use the smaller nozzle pumps when possible though, the big nozzle just flows to much fuel for a fill tube to handle.
Big trucks have a 3" or 4" fill hole right into the fuel tank, no tube involved.
Thanks Dave, I will try this over the weekend. I like the way everybody breaks this stuff down, It helps dummys like me to be able to do this stuff. Thanks and Merry CHRISTmas
bobsals
Apr 24, 2009 04:12 AM
idifamilycab
Jul 2, 2007 09:04 PM
black n black
General Diesel Discussion
Jun 7, 2007 10:29 PM
stanggt
Apr 6, 2004 05:16 PM
Michfar
Apr 16, 2002 08:52 PM
