PCM Swap
Old Dec 24, 2007 | 02:23 AM
RubberDuck's Avatar
RubberDuck
PCM Swap
Will my pcm out of my 96 work in my new 95? Both are standard, but the 95 is 4x4. I'm just wondering because I don't want to have to get my DP reconfigured just yet. I know I'll have to send it back to Jody for the Stage 2's, but I want to use it right now. Any ideas?
Old Dec 24, 2007 | 11:55 AM
1997F-350's Avatar
1997F-350
yes you can .....even use a 97 mle1 if you want.(assuming both are federal pcm's and not cali's) hows she coming cody?
on edit i read your sig. chances are your chip has the mle1 code on it(most up to date). if you dont have a dp tuner pcm then just put your chip on your 95 no need to swap pcm's.. the chip will overide the pcm and you will have whatever code your chip has.
if this doesnt make sense call me.
in other words just put the chip on your 95 with no swapping.
merry x-mas
Old Dec 24, 2007 | 10:37 PM
RubberDuck's Avatar
RubberDuck
Ryan, pm me your # and I'll call sometime even if it's just to say hi. But reguardless, both have to come out anyway. I have to pull No.3's to remove the tuner, and pull Rockee's to clean the contacts. The only diff is one is newer.
Jmudweiser
Sep 13, 2016 05:02 PM
Old Primer Red
Aug 13, 2016 05:32 PM
CrappyPappy
18
Apr 17, 2016 10:21 AM
therigwelder
Dec 18, 2015 07:14 AM
timbersteel
29
Mar 8, 2013 08:32 AM
